11-19-2013, 09:49 AM   #1
WR lens options
I have a new K-50 and currently own the 15 and 40 Limiteds. I'm getting a 70 Limited, and that will be my everyday kit.
I want something WR while keeping the cost down. Would you choose the 18-135 ($364 used) or the 55-300 ($450 new). The latter would give me reach and, at 55mm, a nearly normal FL. The former is, of course, a general purpose range that still leaves me without telephoto capability.
Any thoughts? Other options?
11-19-2013, 09:53 AM   #2
TER-OR's Avatar
Which is more important to you? If you feel hampered by the lack of long zoom, the 55-300 is nice. I don't have the WR version, but the standard is good.
I like the 18-135 but past 100mm the images start to get a little soft. Not unusable by any means, but it's something to consider. It's a great walkaround zoom, but it doesn't have a lot of reach.
11-19-2013, 10:50 AM   #3
SpecialK's Avatar
Clearly the 55-300 for the reasons you mention, plus more than half the focal range of the 18-135 you already have covered, more or less.
11-19-2013, 10:58 AM   #4
jimr-pdx's Avatar
Low-cost WR to me = DA50-200WR. It can be found for quite a lot less than those other two, especially here in the Marketplace. I will probably shift to the 55-300WR in a year or so, but for now the 50-200 does very well. It also takes the same filters as the Limited primes, which is a real bonus on a budget!
11-19-2013, 11:13 AM   #5
I thought about the 50-200, but reviews are not enthusiastic. I haven't used it though.
11-19-2013, 12:49 PM   #6
Just1MoreDave's Avatar
QuoteOriginally posted by DennisH Quote
I am enthusiastic about mine, but I had to fix it before it focused to infinity. The only image quality problem that I have now is some vignetting wide open. And Adobe Camera RAW doesn't recognize it until I choose the lens brand.
I got my K-7 with the 18-55 WR. The 18-135 wasn't out then. I got the 50-200 WR before the 55-300 WR version was announced. Choosing today would be harder. If you know that you will be in iffy weather a lot, you can give up on the long telephoto - 300mm in light rain can't be that good, and you may run out of light for that length. Also lens changes are difficult. That would lead me to the 18-135. It's pretty dry here so I like the 18-55 and 50-200 combination.
11-19-2013, 01:26 PM   #7
bdery's Avatar
It really depends on what you want to do. If you want to supplement your primes with a zoom covering a similar range, the 18-55 WR would be a very cheap and quite decent solution. You could consider getting the 100mm macro WR instead of the 70 and expand on your WR range.
k-mount, pentax lens, slr lens, wr, wr lens
Lens Upgrade Options Greg9 Pentax SLR Lens Discussion 4 05-31-2013 12:12 PM
Options for a longer portrait lens? geekkt Pentax SLR Lens Discussion 39 05-01-2013 10:57 AM
K-30 WR body + spare battery + 18-135mm WR lens + 18-55mm WR lens = 738 jido Pentax Price Watch 4 01-16-2013 04:36 AM
Non WR lens on WR camera . Issue. psychdoc Pentax K-5 4 01-24-2011 11:34 AM
WR body (K7) + Non-WR Lens = meaningless? uchinakuri Pentax SLR Lens Discussion 22 04-01-2010 09:17 AM
All times are GMT -7. The time now is 05:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
