Originally posted by Giklab Edit: TL; DR see Adam's post above
The amount of light entering the mirror box and falling on the sensor doesn't change (f/1.7 = f/1.7 = f/1.7). You're just using a smaller part of that total covered area. Imagine shooting the lens on film. Does the centre of the film have a different exposure? (disregarding vignetting of course)
+1000. f1.7 is f1.7 is f1.7. 50 mm is 50 mm is 50 mm.
The sensor just does not occupy as big an area of the coverage/image circle of the lens.
To the OP: I am not kidding; play around with a large format camera if you have a chance. Stick a 300 mm lens (a 300 mm lens with a big enough image circle, of course, your standard 300 mm large format lens) on an 8x10 camera and play around with 8x10, 5x7 and 4x5 backs. Or play around with a 150 mm lens on a 4x5 camera and 4x5 film plus a roll film adapter back, which may be easier to find for most people. The exposure and DOF will not change though the field of view will change with the format, e.g. the 300 mm lens is a "normal" lens on 8x10 but is a "long" lens on 4x5. The concepts become very easy to understand. And large format can be great fun!
Thanks.
Sincerely,
Hany.
