Originally posted by Just1MoreDave The Pentax-A bellows might work. Otherwise the lens will probably shoot fully stopped down.
The Pentax Bellows-A does not have the A contacts. The lens would always be wide open because the bellows does have a diaphragm actuator (operated by a cable release). Only if you mounted the lens on a non-auto tube would it be stopped down.
Back to the original question, what magnification would you like to achieve? A shorter-FL lens mounted in reverse is a relatively cheap and easy way to get extreme magnification, if that's what you're after.
