Not sure this is the right sub-forum. Please move if necessary.
I recently purchased a Tamron 70-200mm f/2.8 Di LD (IF) Macro AF Lens from a forum member. The listed included the following:
"Item Condition (Key)
Used
Excellent
30 day return policy"
When I received the lens it would not AF properly on my K-01. Searches in the forum turned up others with this problem and an email to Tamron confirmed there is a problew with this lens on the K-01. I then took some test shots with my K-3 and was disappointed in the sharpness of the lens, given it's excellent reviews in the forum.
I have subsequently sent it to Tamron USA for a tune-up and received the following back:
Warranty: NO Serial Number: 006166
Symptoms:
- SK EVIDENCE OF SHOCK DAMAGE
- BIX BROKEN INTERNAL PARTS
- F FOCUS DEFECT OR POOR IMAGE QUALITY
- AF AUTO FOCUS IS NOT FUNCTIONING CORRECTLY
- D DUST OR DEBRIS INSIDE LENS
- C INTERNAL CAM BARREL IS BENT OR CRACKED
- O OVERHAUL/CALIBRATE TO FACTORY SPECS
Repairs:
- SK REPAIR NON-COSMETIC PHYSICAL DAMAGE.
- BIX REPLACE ALL BROKEN INTERNAL PARTS.
- F CHECK AND ADJUST FOCUS AND IMAGE QUALITY.
- AF ADJUST AUTO FOCUS SYSTEM.
- D DISASSEMBLE AND CLEAN ENTIRE LENS.
- C DISASSEMBLE AND REPLACE/LUBRICATE CAM BARREL.
- O COMPLETE OVERHAUL, CLEANING & ADJUSTMENT.
Repair Charge - 35mm Lens A001 1 $320.00
I have ok'd the repair even though the cost plus the price I paid for the lens exceeds the cost of a new one.
What would you do? Contact the seller or figure it is buyer beware.
