11-27-2013, 02:54 PM   #1
Just1MoreDave's Avatar
Documenting old lens names in EXIF
I stumbled on a plugin for Lightroom 3 or higher that helps change the lens name to something more useful. I posted some information about it in the software section here:
https://www.pentaxforums.com/forums/32-digital-processing-software-printing/2...al-lenses.html
Lightroom resists making this change which makes the plugin not as smooth as it could be. But finding and selecting the images is a lot easier in LR, especially if they are all RAW like mine are. It's easy to use the filters to choose "A-series", K or M" and "Unknown" lenses to see which ones need names. I have used a lot of non-AF lenses that don't record any data in EXIF. Now I'm working on the last 2000 unnamed lenses in my catalog, hoping to get 95% of the names recorded.
I am writing all these names to the DNG file EXIF directly, so they are not dependent on Lightroom.
Unfortunately, this is just a name and not a code that would help some Sigma users with misidentified lenses. You could correct the names but it might not make lens profiles work automatically. I have seen others complain that the lens names can't be changed with import presets.
If I remembered to set the focal length correctly for SR, I can usually dredge up a memory of what lens it is. Unless it's 50mm. The A series lenses also have an aperture setting, narrowing it down. I have a lot of moon shots, and the size of the moon helps with focal length, leaving only a few possible telephotos. After a few lens tests, I got smarter about taking hundreds of shots of the same subject with like seven lenses, and began putting a post-it note in the shot with the lens name. The last 5% of shots will be mostly from my *ist DS, a long time and many lenses ago.
11-29-2013, 08:18 PM   #2
SpecialK's Avatar
It would be nice if we could designate the lens name in the body, like AF adjustments...
exif, k-mount, lens, lens names, lenses, lightroom, lot, moon, name, names, pentax lens, shots, slr lens
Lens information missing in EXIF civano Pentax K-3 24 11-23-2013 01:53 PM
Lens ID in Exif data Pentax Bob Troubleshooting and Beginner Help 7 06-28-2013 02:50 AM
No lens identifier in EXIF data hastingd Troubleshooting and Beginner Help 6 06-11-2013 04:52 AM
Some Old Names.......Remember? Rupert General Talk 104 03-25-2013 10:30 AM
Lens misidentified in EXIF gebco Digital Processing, Software, and Printing 9 06-07-2012 03:53 AM
All times are GMT -7. The time now is 06:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
