11-30-2013, 11:29 AM   #16
NitroDC's Avatar
I'd buy the 15mm just for the flare resistance. It's incredible.
11-30-2013, 12:09 PM   #17
Canada_Rockies's Avatar
For those considering it, I have a series of DA 12-24 images on my Flickr site that demonstrate its flare resistance, etc. I'm quite happy with it. And I have 12,13,14,15, ... 24 mm point of view without changing lenses. The distortion is very good for a zoom in this range which is a nice bonus.
11-30-2013, 07:42 PM   #18
Shanti's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Hi what about PF? is that a problem as I do alot of outdoor work,trees,rocks etc.. using K5II
11-30-2013, 09:01 PM   #19
Check out my test shots here. Into the sun, trees against the sky, etc. Flickr 12-24
Many are wide open at f/4. Right click, select original and you can see the EXIF
11-30-2013, 09:10 PM   #20
Beautiful shots of the Rockies - must get there sometime - for my edification, is the purple showing in the shade of BC-5 considered lens flare, internal reflections in the lens or something else?
11-30-2013, 11:03 PM   #21
QuoteOriginally posted by PeterDM Quote
Yep, that's flare all right. The sun is in the frame at the top, making for a worst case. If you look at the ones to either side, moving the sun just out of the frame makes a great difference. As I mentioned, I was trying the lens out to see what I needed to watch out for.
12-01-2013, 12:17 PM   #22
Shanti's Avatar
hard to see on small sizes,but there is some PF in some of the trees...is it easy to remove in PS? plan to print 30x40cm or so ..really torn between this lens & 15mm..do you know if most UWA have PF,like Nikons or Samang for example?
12-01-2013, 12:26 PM   #23
normhead's Avatar
The best combo in the WA end is the Sigma 8-16, along with the Tamron 17-50. The Sigma 8-16 is corrected for barrel distortion down to 12mm, so you can do panos @12 mm….hard to beat in a WA lens.
12-01-2013, 12:43 PM   #24
Normhead: yes i like ur zoom combo...cos i use that same also
anyway there is one thing in 8-16 i am not happy, no filter thread for my landscape pics.
12-01-2013, 12:47 PM   #25
normhead's Avatar
QuoteOriginally posted by Joojoo2010 Quote
The fix for that is an oversized filter attached to the lens with gaffer tape.
12-01-2013, 01:05 PM   #26
Shanti's Avatar
would you recc. over Da12-24? about to buy one on BF sales now--
12-01-2013, 02:46 PM   #27
QuoteOriginally posted by Shanti Quote
When you are looking at an image, right click and select "orginal" and you will be looking at it uncropped. Yes, the PF can be reduced significantly in post processing. Those images are just dumped up there so people can see what the lens acts like and decide if it is for them, as you are doing. I just took a series of family group portraits with the same lens and camera with no weird results at all.
12-01-2013, 03:17 PM   #28
normhead's Avatar
I haven't tried enough WAs to comment on all of them, before the 8-16 we were looking at the 10-20, but lot's of people also recommended the 12-24. ANd I'm not sure the 8-16 is still available in K-mount. Last time I talk d about it , it was with someone who was trying to find one.
12-02-2013, 07:19 AM   #29
Shanti's Avatar
Just ordered the 12-24 from B&H..so will post some photos when it arrives..
12-02-2013, 02:35 PM   #30
I trust you are happy with your purchase as I'm waiting on delivery of my 15mm from B&H.
angle, k-mount, lens, pentax lens, pentax-da, slr lens, wide angle on landscape
Wanted - Acquired: Wide / Ultra Wide angle lens for my K-5 GWARmachine Sold Items 3 03-23-2013 12:03 AM
For Sale - Sold: Rokinon 28mm f/2.8 Wide Angle MF lens K mount dcshooter Sold Items 2 01-23-2012 09:49 PM
Recommend wide-angle lens for K10D Green_Manelishi Pentax SLR Lens Discussion 12 06-05-2009 01:26 PM
Budget wide angle lens for K100D? FckShoes Pentax SLR Lens Discussion 19 06-27-2008 06:45 PM
Wide-angle lens to replace K10D kit lens StacyA1973 Pentax SLR Lens Discussion 20 03-07-2008 02:43 PM
All times are GMT -7. The time now is 04:36 AM. | See also: NikonForums.com, part of our network of photo forums!
