04-04-2008, 01:22 PM   #1
Telephotolens tryout, go ahead and boast.
Would some people be intrested in leaning out the window and take a picture of some people say, 100m-200m away with their longest focal lengths and post the results?
I am about to have two challenges this summer. First I am going to be taking photos on concerts here. And it seem I will be able to join and take photos of some explosive trainings for a bombunit.
Niether of these will let me closer then 100m-200m though. The second I might have to be as long as 400 meters away. Are there any chance of getting any good results when it comes to people shots? Will I even be able to see what they look like? I only have a 200mm lense and this is what a crow looks like 400m away with it.
Crow
04-04-2008, 01:36 PM   #2
A 200mm lens should give you a ratio of about 1:7 for 'picture width':distance on a crop sensor camera.
That would be 70m distance results in a 10m wide image @200mm focal length.
Or 210m in a 30m wide image. And with a 300mm lens, it should be around 20m wide. And so on.
You can easily find out by yourself. Just take a shot of something, say, 10m away. Then watch the image and estimate how many meters you have covered in width or height.
This ratio stays constant for what ever distance you are shooting at for a given focal length.
Or, well, just take a picture of a ruler ...
Of course, sharpness is a different thing ... If your crow isn't sharp, nothing else will be ... I guess.
04-04-2008, 01:50 PM   #3
Lowell Goudge's Avatar
As a simple calculation, with any lens for relitively distant subjects
Image size = Object size x focal length / Object distance
Consider a person 2 meters high (about 6'7") 400 meters away, with a 400mm lens (0.4meters)
your image is 2mm high on a 24mm x 16 mm sensor (ASP-C sensor size) or with a horizontal format about 1/8 of the frame height.
On the K10D that makes the entire person 324 pixels high or each pixel is 6 mm (about 1/4 inch in terms of the subject)
04-04-2008, 02:02 PM   #4
But calculations are not as fun as seeing results from peoples lenses . No calculations will show what lenses makes good results
But thanks for the answers, don't want to sound ungrateful, because I am not.
So with a 2x TC and a 400mm lens a 2m person would take up about 640px height? Thats not too bad, for internet usage, but what will the quality be?
04-04-2008, 03:38 PM   #5
QuoteOriginally posted by Zewrak Quote
No offence taken. the reason to give you the calculation is so that you can better plan what lenses you need.
with the data I gave you, take any image you have of a person standing at a height of 1/8 to 1/4 of the frame and look at the quality.
As long as you have a good lens and are focused and hold the lens still you should be OK.
one thing I have noticed however is that when things are that far away, and the object so small, sometimes vibration and camera shake causes you to move the focusing sensor off subject and focus is off because iot is picking up something else
04-04-2008, 04:10 PM   #6
Well I wont be fiddling with any fast moving objects. Except for explosions . And I will be able to use very stationary tripods and stuff, so the stability will be as good as it can be. Im thinking manual focusing and a heavy tripod and possibly mirror up shooting.
Anyways, won't light start to fall off quite drastically at that distance though, can I really expect the same sharpness as a photo taken with a 50mm with your calculations? Shouldnt there be more information into the equation?
What lenses could pull this off? A Bigma? Or do i need a bigger aperture? Lets say for the sake of argument that I want to take a picture at 300 meters distance on people kneeling down and fiddling with wires and stuff. Are there any lenses good enough to really be able to pick up enough light to get the details going, not considering the size of the people.
04-04-2008, 05:02 PM   #7
ryan s's Avatar
How long are you looking for? There are lenses like the Tamrom SP 500 f/8 mirror. They do produce odd, donut like bokeh and are somewhat difficult to focus. But it's hard to beat a mirror's value.
04-04-2008, 07:44 PM   #8
I have a 1000mm celestron C90 spotting scope with a T Mount
works out to F11
bump the ISO up a little and your 2 meter man at 400 meters becomes 1cm on the sensor or 5/8 the height of a frame.
Just make sure your stable. it is really sensitive to vibration. not only do you need a stiff tripod, but hang your camera stuff from it to weigh it down
As long as you are v
crow, k-mount, pentax lens, people, photos, results, slr lens
I feel the need to boast! jadedrakerider Pentax SLR Lens Discussion 5 10-23-2009 12:31 AM
Pentax Digital Camera Utility 4 tryout (with images) creampuff Digital Processing, Software, and Printing 4 07-10-2009 10:42 AM
A Couple For The Album (DA 55-300mm tryout) creampuff Post Your Photos! 7 06-22-2009 07:32 AM
Picture posting tryout gamgee Pentax DSLR Discussion 4 05-25-2008 02:03 AM
First tryout with panning barbosas Post Your Photos! 0 06-01-2007 03:40 AM
All times are GMT -7. The time now is 11:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
