12-10-2013, 03:29 PM   #76
QuoteOriginally posted by woodywesty Quote
What kind of pattern are you seeing in our serial number data base? I'm curious because I'm really confused about the whole random use of serial numbers. Sounds pretty odd to me. I still really like my new lens and have my fingers crossed that it will be a good one. We need an "insider" at Pentax in Japan.
OK, Serials starting with 901 go back to mostly 2007-2008, 902 mostly 2008-2009, 903 mostly 2009-2010, 904 mostly 2010-2012 and 905 is 2013
that is when they were acquired by the forum members that posted their serials.
These are pretty darned good lenses. The problem is playing roulette with the SDM and the older the lens, the more likely it fails. That failure costs $240 to repair. My first lens was a 901 serial and it failed this last spring.
12-10-2013, 07:39 PM   #77
QuoteOriginally posted by GaryH Quote
and I just got a 903 from black Friday
12-14-2013, 02:04 PM   #78
krebsy75's Avatar
No response from B&H... Weird. What did you guys end up doing?
12-14-2013, 04:21 PM   #79
QuoteOriginally posted by krebsy75 Quote
I kept mine. I am convinced that Ricoh has not overseen any production of that lens. It is a fair price and if they come up with a replacement, it will be $1500.
12-14-2013, 07:27 PM   #80
My recommendations to everyone fretting about their Pentax 16-50:
I bought a brand new perfect, box never opened 16-50 with serial number 904xxxx, around 2011.
Basically never used it. SDM always kind of slow at first. Completely failed in 2013, and lens was switched to screw drive only using my K20D.
This is a really super lens. I love it. Optically and cosmetically really nice, with great range 16-50. Weak only at 16/2.8.
SO......just buy the lens, and plan on switching to screw drive WHEN the SDM fails. No problem, as long as you have or get access to an older Pentax DSLR. Your surprise will be that you WILL NOT MISS THE SDM. Screw drive on this lens is remarkably quiet and just as fast, or faster, than the stupid SDM. I would pay MORE for a screw drive version of this lens.
Once in screw drive, you can enjoy this great lens for a very, very long time. No need to ship it in for an expensive repair, which might mess up your lens and will probably not permanently fix it anyway.
12-14-2013, 07:47 PM   #81
NitroDC's Avatar
My lens has a small bit of dust on the inside of the front element now. Only had it since black friday. Is this something to worry about? As another note my zoom ring gets a little stiff in the 28mm region -- could my WR seals be faulty (and the cause for the dust on the inside and the stiffness)?
I'm certain the dust speck was not there when I got the lens.
12-14-2013, 08:22 PM   #82
QuoteOriginally posted by NitroDC Quote
Both my new and old 16-50 had that stiffness at 28-30mm. The 60-250 has the same thing.
Should not be a problem. I would consider having it switched for another lens if it has dust though.
12-14-2013, 08:30 PM   #83
NitroDC's Avatar
I just shined a flashlight into it...
There is some tiny dust present further in.
I'm thinking it's just dust that has gotten in while the lens had the rear cap off or dust that was in the camera and got sucked in while zooming. I mean these aren't weather sealed even on the insides. They are only sealed from the outside elements. I am reluctant to replace this one anyways since it's a sharp copy.
12-14-2013, 08:37 PM   #84
If it is a sharp copy keeping it is more important than a little dust for sure.
12-15-2013, 07:23 AM   #85
krebsy75's Avatar
The stiffness people talk about is most likely the ratio changing in that zoom region. Normal operation.
12-15-2013, 09:49 AM   #86
i ordered from B&H and i as expected i got a Hoya version of the da*16-50
if i am not mistaking the price in B&H was lower than other online sellers
so at time of ordering i knew that there was going to be a higher chance to get a Hoya version from b&h as opposed to Amazon for example where it was not in stock before and the price when it became available was higher before tax..
i will keep mine, but Ricoh has an opportunity to continue to increase market share if they would issue an extended warranty for sdm products and give people confidence to continue to buy Pentax Ricoh products. Ricoh Pentax lenses warranty 1 year and 6 weeks repair time?;,,,,,, compare to Tamron 6 years warranty and 3 days to repair; Sigma 4 years; Nikon 5 years 10 days to repair, therefore it is just a question if Ricoh wants to increase market share or not.
12-15-2013, 10:05 AM   #87
QuoteOriginally posted by Rudy Quote
I think you're "spot on". I also bought the 16-50 in late October and am going to take a wait and see position. I like the lens but would like for Ricoh to at least say something to us. If it doesn't work out there are a number of very nice lenses from Sigma for me to build my lens collection.
12-16-2013, 07:12 AM   #88
I finally got a response to my Ask B&H post. They can't confirm manufacture date. They *think* recent lens shipments were received after the rumored 2012 SDM change. B&H probably doesn't want to take on Pentax' mistakes.
I have been using my 16-50. It's soft at the edges wide open, as I expected from reading reviews. CA at high contrast edges is easily correctable in Lightroom. Center sharpness at f2.8 is better than I expected - much better - so I want to keep my copy unless I find a showstopper. Some samples posted to https://www.pentaxforums.com/forums/12-post-your-photos/245558-people-too-many-santas-faces-santacon.html
The only surprise is a little bit of barrel wobble. At 50mm I can wiggle both portions of the extended barrel. It is very slight and doesn't seem to impact IQ or WR.
k-mount, lens, lenses, papers, pentax lens, slr lens
There is air blow out when I zoom my 16-50, is this normal? liukaitc Pentax SLR Lens Discussion 21 05-10-2012 08:55 AM
Does it matter when my K5 was made? SenorBeef Pentax K-5 14 04-06-2012 05:32 PM
Brand new DA* 16-50 squeaking when focusing....??? Loren E Pentax SLR Lens Discussion 10 01-11-2011 10:35 AM
There was a time when FA50mm/F1.4 was under $200? Retail? sjwoo Pentax SLR Lens Discussion 17 03-17-2010 03:35 PM
What are the odds that my new 16-50 will be a good copy skinja Pentax SLR Lens Discussion 10 05-20-2009 05:07 PM
All times are GMT -7. The time now is 07:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
