12-07-2013, 12:01 PM   #46
Cool, I haven't the required weather conditions to test it against flare, looks perfect on the first shot !
12-07-2013, 12:06 PM   #47
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by goubejp Quote
The extreme right is soft, though.
Were you standing perfectly square to the scene? It's hard to tell from the photos. The reason I ask is that the softness on the right appears to be a DOF issue. If you were turned even slightly to your left that would put what is on the right closer than that which is on the left. IF that is the case, depending on what you were focused on, it's conceivable that the extreme left was within the DOF and the right wasn't. Try a classic "brick wall" test, making sure the sensor is absolutely parallel to wall.
12-07-2013, 12:44 PM   #48
Doesn't look as a DOF issue for me, the transition would have been more smooth. A slight centering issue for me, but not sufficient to return the lens. Most of wide angle lenses has slight centering issues.
12-07-2013, 02:55 PM   #49
Better than nothing... with overcast weather and night, portrait of my favorite pet.
Remember that quality has been decreased cause of ImageShack limit to 5 Mbytes
http://imageshack.com/a/img15/8527/gcve.jpg
100 % crop on the eye, full quality
12-07-2013, 04:27 PM   #50
Looks pretty good to me. If mine's at least that good it'll be a keeper. I actually may have lower standards for the lens than many others. I was going to buy a DA21 just because I wanted something in that range, but I could never get excited about it. The 20-40 was announced right about then and would give me that range, plus some "zoomability," WR and a DC motor, so I figured it was worth a little more. As long as the 20-40 is at least as good in IQ as the 21 (hopefully a little better) I'll probably be happy with it. I'll find out Monday.
12-07-2013, 05:34 PM   #51
Vylen's Avatar
Looks pretty good from what I can see. Sharpness seems to be a chase of pixel peeping (which isn't a bad thing).
Other things that need to be compared are distortion and bokeh I guess. Then it just becomes a case of convenience; carrying 3 primes or 1 zoom. Unless you do need the wide aperture of the primes of course.
12-07-2013, 07:05 PM   #52
krebsy75's Avatar
Keep your expectations high. A thousand dollar lens should be pretty damn good.
12-07-2013, 07:12 PM   #53
QuoteOriginally posted by krebsy75 Quote
Yes, but I only paid $896, so it only has to be that good.
12-07-2013, 07:45 PM   #54
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by DogLover Quote
Right. It only has to be 89.6% as good as a $1000.00 lens.
12-07-2013, 11:36 PM   #55
ogl
Banned
The last photo is very good in terms of sharpness.
12-08-2013, 03:19 AM   #56
My impression after comparing side by side, and with a large experience of the DA21, is that the zoom is largely better - more homogeneous, sharp side from side at f4 (which is not the case of the DA21 !), same amount of CA. We shall see about distorsion - but the DA21 is not a good performer here - and color rendering.
12-08-2013, 10:15 AM   #57
Hard to say on this it's not got much of a size edge over the Tamron, if they ever update that lens with a USM motor and sealing and charge a bit more it would be a huge hit.
I'd want to see more samples on the new Pentax though before hammering it down.
12-08-2013, 10:47 AM   #58
QuoteOriginally posted by Mr Spocko Quote
It does if you consider the Tamron with the hood attached.
The Tamron is an excellent lens,
but the hood needs to be reversed for storage,
and it takes a good few seconds to remove and attach.
For grab shots, I just leave the hood reversed,
since it doesn't interfere with the focusing.
I'm hoping the new DA zoom will be quicker on the draw.
12-08-2013, 10:48 AM   #59
Crooski's Avatar
Distortion DA 20-40
Today I have a number of recordings made ​​by a stone wall.
At 20 30 and 40mm.
Maximum Aperture 2.8 3.5 and 4.0 at 40mm.
There is a clear distortion at 20mm.
These three shots.
12-08-2013, 10:49 AM   #60
The downside of that, it would probably be a VC version,
with lower image quality (deliberate decentering!) than the current A16.
k-mount, pentax lens, slr lens
The DA limited is 20-40? and WR?! LFLee Pentax News and Rumors 1331 02-13-2014 10:55 PM
DA 20-40 Limited zoom availability lytrytyr Pentax SLR Lens Discussion 20 12-05-2013 03:21 PM
DA 16-50 or DA 20-40 Black Friday mtngal Pentax SLR Lens Discussion 7 11-29-2013 05:20 PM
DA limited 20-40 f/2.8-4 rlatjsrud Pentax SLR Lens Discussion 3 11-02-2013 11:04 AM
DA 40 Limited has arrived! jsherman999 Pentax SLR Lens Discussion 22 06-16-2008 08:28 AM
All times are GMT -7. The time now is 08:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
