The indoor shots look as if the camera is tilted every so slightly downward. I'm going by the perspective distortion by the window. The brick wall looks perfect. You might be a little bit thrown off by the ultra wide distortion that is stretching the bricks in the corners. This is a characteristic caused by optics when three dimensional scenes are projected onto a flat surface.
From those five images, your lens is working as well as any 12mm lens out there, much like mine. Now you need to stop worrying and just enjoy the lens. Too much pixel peeping ruins the fun, I find when I start doing it (and we all do, mostly).
To upload to the forums as an attachment, click the
[go advanced] button and upload from your computer. You can upload to the user gallery on Pentax Forums, too, and then use the shown below the image, like this below. Scroll down when you get to the gallery, and you will find a block of code bracketed by the IMG tags. To upload to the user gallery here on the top bar of the forum view, click "Photos", then "User Photo Gallery", then "Upload Photo". If you right click the image below and select "View Image Info" you can see the code you are looking for on your own photos.
