12-17-2013, 03:42 AM   #1
DA35 2.4 vs Sigma Art 30 1.4 ?
Any experience with these two options?
I plan to use it for video as well.
I haven't used these lenses at all. In a way, i guess they will both perform well.
But maybe one has a specific advantage over the other?
I would be considering the DA 35 ltd macro + sigma 30 1.4, but that would have to be a 2 step purchase with a year in between...
thks!
chr
12-17-2013, 05:26 AM   #2
rbefly's Avatar
Apples and Oranges?
Hello grispie,
I only have the DA 35mm f/2.4, not the Sigma, so bear that in mind.
While I'm very pleased with the overall sharpness, resolution, color rendition and AF speed of the DA 35, it must be understood that this is a consumer-grade lens. It is made to a specific price/user point and some sacrifices are necessary. The plastic bayonet mount, lack of quick shift, no (supplied) lens hood, somewhat lightweight construction (although, to be fair, I've found it to be sturdy enough for normal use), AF drive motor and likely some compromises in the actual materials used for the optics. For $200 USD, it is a very good value, but it's not high-end glass.
According to many reports, the Sigma Art series is made to very exacting specs, is all (or, mostly) metal construction, very well-corrected optically, features quick-shift, metal bayonet, HSM focusing motor, is 1-1/2 stops faster than the DA and would definitely qualify as high-end. The price reflects this, currently $900 USD.
The DA 35mm Macro would be a much closer comparison in quality, both in optics, quality and construction.
Again, the DA 35mm f/2.4AL is a fine lens, just browse the 'Plastic Fantastic!' thread. But, like most things in life, you get what you pay for!
JMO,
Ron
12-17-2013, 05:34 AM   #3
azerak's Avatar
I'm confused. You said ART. So are you referring to Sigma ART 35mm 1.4 or the Sigma DC 30mm 1.4 or the Sigma ART 30mm which is not available for Pentax mount?
12-17-2013, 05:52 AM   #4
QuoteOriginally posted by azerak Quote
I was referring to the Art 30mm 1.4 for which i am sad to hear it would not be available in Pentax mount. Will it be futurewise?
The 35mm Art is very expensive but still attractive, yes...
12-17-2013, 05:57 AM   #5
azerak's Avatar
QuoteOriginally posted by grispie Quote
As of now, I dont think it will be available in Pentax mount. Unless Sigma makes a surprise announcement or some sort.
12-17-2013, 06:24 AM   #6
then, except for the quite expensive and big 35mm Art, are there other alternatives?
(well, the "old" 30mm 1.4 i guess)
I'd like sthing with a big focusring..
12-17-2013, 07:25 AM   #7
TER-OR's Avatar
The Sigma 28mm f1.8 macro might be worth considering. It is big...
12-17-2013, 07:36 AM - 1 Like   #8
Kozlok's Avatar
The original Sigma 30/1.4 EX/DC is available used. For rendering, I'd say the Pentax is better if you want across the frame sharpness. For center sharpness only, or shallow DOF, the Sigma is better (eg portraits)
12-17-2013, 08:04 AM   #9
Emperor and Senpai
VoiceOfReason's Avatar
From everything I see about it I would go for the Sigma 18-35 f/1.8 over either of them. Supposedly it's like having a bag of primes on sharpness and it's pretty fast too.
12-17-2013, 08:57 AM   #10
QuoteOriginally posted by VoiceOfReason Quote
the thing is that i have a DA15 and a DA70.
I'd be ok with a 30mm fast prime. the old sigma 30mm might do the trick. the sigma 18-35 is very attractive but relatively expensive and bulky. Seems a good lens for video though.
QuoteOriginally posted by TER-OR Quote
thks, i'll look at it tonight.
12-17-2013, 09:11 AM   #11
There's always the Pentax FA 31 Limited. It costs more than the others listed, though the Sigma 18-35 is in its ballpark. It's truly great.
12-17-2013, 09:51 AM   #12
starbase218's Avatar
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
If the Sigma Art 30/1.4 would be available in Pentax mount, I'd probaby get it to replace my 35/2.4. The Art 35/1.4 is better but much bigger and heavier and the old 30/1.4 isn't as good optically (from what I've read). The Pentax FA 31/1.8 is expensive. The FA 35/2 is another option, but not that much better than the 35/2.4 (only a bit faster with more PF at those apertures).
12-17-2013, 10:28 AM   #13
I had both the Pentax DA 35mm and the a Sigma 30mm EX DC f1.4. I sold the Pentax and kept the Sigma. While the Pentax is technically more consistently sharp across the frame, the Sigma is outstanding in the center and much faster. For what I do (weddings, fashion, portraits), sharpness in the far corners is not terribly important, especially considering I usually shoot at wide apertures so the corners would be blurred anyways.
It depends on what you need out of your lens. For example, I wouldn't recommend the Sigma for astrophotography because of the weak corners and pronounced coma around the margins of the frame.
12-17-2013, 12:37 PM   #14
StephenHampshire's Avatar
QuoteOriginally posted by Drake Avenue Quote
Young Drake there has a point. I had the 35mm F2.4 and sold it. I have the 30mm EX DC F1.4 and use it, partly because I have decided I much prefer the wider focal length. F1.4 is, well, quite fast, and there are times I like to have the speed (normally when I am photographing moving things in poor light. The Sigma does have rather strange rendering at the extree edge of the frame, but the centre is sharp. It is not a large or heavy lens, but is well built. I have nothing against "plastic fantastic" lenses btw, I have the new DA50 f1.8 and prefer it to my F50mm 1.7 (although the M version is the nicest!)
12-17-2013, 03:13 PM   #15
QuoteOriginally posted by StephenHampshire Quote
i agree, with the crop factor, i'd rather have a 30mm or below...
da35 2.4 vs, k-mount, pentax lens, sigma, slr lens, vs sigma art
new Sigma 30/1.4 "Art" not available for Pentax kevwil Pentax SLR Lens Discussion 53 02-14-2014 05:48 AM
DA35 2.4 vs FA50 1.7 chesebert Pentax SLR Lens Discussion 21 06-05-2013 07:46 AM
Sigma 30 1.4 vs. Sigma 28 1.8 lux-ad-artem Pentax SLR Lens Discussion 13 10-12-2012 11:43 AM
da 35 2,4 vs sigma 30 1,4. what to get? fikkser Pentax SLR Lens Discussion 27 11-14-2010 01:12 PM
Sigma 30/1.4 vs DA 70/2.4 ytterbium Pentax SLR Lens Discussion 26 05-21-2009 03:34 PM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
