Originally posted by normhead So I assume , that you have images taken with a corrected lens, right off the camera to share, and an another image, taken with a similar but less corrected lens, that needed correction, that has been corrected in light room to compare it with?
No, that's not what I mean. The only way to test the effectiveness of PP on CAs is to use the same image from the same lens. Once you introduce different lenses you've lost all control of your variables. Generally speaking (although it's hardly true universally), lenses that are better corrected for CAs will also be better all in many, if not most, other respects. When lenses are made toward a specific price point, there are tradeoffs involved, and oftentimes if the lens designer must choose between either more resolution and microcontrast on the one side, and less corrections of CA on the other, they will choose the microcontrast and the resolution. This is basically the philosophy behind Panasonic lens designs. Panasonic doesn't bother much with either CAs or even distortion, preferring to fix all that in the camera. Even the RAW files are corrected. Software-based CA correction can be quite effective.
Consider the following image taken from the DA 10-17:
Now let's look at a 1:1 view of the image uncorrected for CA:
You can see come green and purple CA along the edges of the snow bank, and some very slight CAs on some of the edges of some of the rocks. Here's the version corrected in Lightroom:
I can't see any difference between these two versions, other than the CAs are gone in the second crop. Perhaps if you pointed an electron microscope at these images, there might be a palpable difference; but that's not how these images are meant to be viewed.
