Originally posted by schnitzer79 one last question guys. I was using centre-weighted metering for the show.do you think i would have got better results if I had switched to spot metering?
Show us some sample images
It highly depends on the scene and the light what will work better. But I think center weight will, in general, be fine. Remember that in any metering mode, you can use eV compensation depending on the requirements.
All images in
https://www.pentaxforums.com/forums/12-post-your-photos/163422-people-toyota-...mb-photos.html were shot using center weight metering. Although the light conditions and the action probably does not match yours, I can't remember that any of them was shot wide-open (most stage shots were ISO3200, around f/4 and shutter speeds around 1/300s). Lenses used were FA31Ltd and DFA100WR.
Note:
You can always push a bit in PP if necessary, so underexposing a tad to achieve better shutter speeds is also an option.
