04-07-2008, 07:28 AM   #1
Rorschach's Avatar
Old M42 extreme telephoto primes and TC's?
Hello everybody!
I'm wondering if anybody has tried a combination of a modern TC (Sigma 1.4 or 2.0) and an ancient M42 extreme telephoto prime (especially the Takumar 500mm f4.5). I happen to have a Sigma 1.4 TC lying around and am considering the Takumar.
Thanks for any info,
Boucicaut
04-07-2008, 09:44 AM   #2
Not Registered
Guest
I have no experience with that particular lens and an adapter. I have used other m42 lenses (Zeiss 200 f2,8 and Telemax 200 f3.5) with the pentax AF1.7x adapter and it focused with the normal limitations. What you will loose with your sigma for sure is the autofocus capability cos you can only use the pentax 1.7x to transform a manual lens in an semi-autofocus one. In my case, the mixture worked well and IQ was only bad at wide open apertures.
04-07-2008, 02:55 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by Boucicaut Quote
Hello everybody!
Boucicaut
The Takumar has high enough image quality to be used with the TC, provided you get the Super-Multi-Coated or S-M-C versions. Note that you will need an excellent quality TC to use with this combination. You will probably have the dreaded chromatic aberrations as well.
k-mount, m42, pentax lens, sigma, slr lens, takumar, tc, telephoto, telephoto primes
Extreme-telephoto?!? AF or MF?? bollicina31 Pentax SLR Lens Discussion 16 10-24-2010 01:03 PM
Extreme Telephoto/Mirror Lens? Julie Pentax SLR Lens Discussion 4 09-05-2010 04:38 PM
Why do people love super telephoto primes? esman7 Troubleshooting and Beginner Help 29 08-28-2009 09:50 PM
Don't let this happen to you: using M42 Long telephoto lens vizjerei Pentax SLR Lens Discussion 32 12-17-2008 05:47 AM
M42 Ultra wide primes that are sharp and contrasty imadethis Pentax SLR Lens Discussion 4 09-10-2007 06:52 PM
All times are GMT -7. The time now is 01:54 PM. | See also: NikonForums.com, part of our network of photo forums!
