Originally posted by kh1234567890 Are you going to persevere or just give up and keep your old SMC since that appears to be the only DA 55-300 that Pentax had ever managed to set up properly ?
I wasn't as careful in testing when I got my DA. My first DA was glaringly blurry at 55mm on the entire left side. So I exchanged it for another, which was fairly uniform across the frame at with the test chart, and seemed ok in practical tests (couple of hundred images.) Basically I declared victory too soon. Subsequently, I used the lens at 300mm to photograph a (large) bird across a pond, with a uniformly distant background of foliage. Foliage in the upper right was blurry. So I tested with printed characters at several hundred feet, and sure enough the upper right was obviously worse than my 100-300F. Everywhere else, the DA was better. So as a practical matter, my DA is fairly good 55-200ish lens. Subsequently I tried two more DA's (4 total), one of which was worse overall than mine, and the other of which was different (better at 300mm), but inconclusively better or worse overall, so I kept mine.
I'm tired of testing 55-300s. I want Pentax to test them so I don't have to. Probably if 90% of these lenses - probably the actual defect rate - got returned, that would get some attention from Pentax. But not enough consumers test lenses - I know I didn't. Or maybe they just care about center performance, especially with telephotos, in which case any of my copies would have been acceptable.
I wouldn't mind paying more for a lens with consistent performance with the same range and features. I don't need or want the physical size/weight of a Tamron 70-210 or 60-250DA, and since I'd be very satisfied with the performance of a combination of the 55-300s, I don't think I should need to carry more weight just to get consistency.
