12-29-2013, 04:44 PM   #16
I just registered the warranty for the lens and have 3 years, 11 months, and 16 days left on the warranty. Hopefully I won't be needing it, especially due to an 'extreme temperature' incident.
12-30-2013, 09:38 AM   #17
Canada_Rockies's Avatar
If anyone wants an old clunker that works in any weather, I own an SF-1 with the cold weather battery pack -- a 4 AA holder, 1 m cord and battery door replacement. The cord is long enough to put the batteries in a shirt pocket inside parka, sweater, etc and still reach the camera. I no longer use it.
12-30-2013, 11:56 AM   #18
EarlVonTapia's Avatar
I've used my K30 in -25 C with no major issues (it was a bit sluggish, but it made it).
If you have to use your gear in cold weather but are concerned with keeping it cold for too long, perhaps try a couple of those disposable hand warmers tossed into your camera bag to help keep them warm.
12-30-2013, 01:41 PM   #19
When we are talking about temperatures we have two temperature ranges to consider:
1. The storage temperature range - the range of temperatures over which the thing can be stored without damage, such as in an un-airconditioned place or a bag when in transit, or a hot car in the sun on a day when the official temperature is 46C.
2. The temperature range over which it will work properly. e.g. expansion/contraction of metals etc could cause dimension changes in a lens that result in it not operating within spec, but on return to inside the envelope temperatures it will return to normal operation.
The temperatures in 1 are likely to be quite absolute with damage resulting if it goes outside the range.
The temperatures in 2 are likely to be the limit of guaranteed proper operation, and some kind of degraded operation is likely outside the range.
Batteries are the most likely problem for cameras in low temperatures - i.e. they cease to perform at the highest temperature of the limits of any other part of the camera.
k-mount, pentax lens, slr lens
What is a good zoom lens for reverse lens macro? dmbaile2 Pentax SLR Lens Discussion 5 08-15-2012 11:32 PM
What is considered high mileage (shutter count) kjfishman Pentax DSLR Discussion 7 12-29-2011 06:55 PM
What's a good, cheap lens for indoor, low light situations? mojoe_24 Pentax DSLR Discussion 31 01-19-2011 12:02 AM
What is considered correct expsure? schmik Photographic Technique 34 08-28-2009 01:25 PM
How many shots is considered to much for a used camera? Sitting Bull Troubleshooting and Beginner Help 8 02-02-2009 01:40 PM
All times are GMT -7. The time now is 08:12 AM. | See also: NikonForums.com, part of our network of photo forums!
