At the moment my kit consists of
Sigma 10-20mm f4-5.6
Pentax F 35-70mm f3.5-4.5
Sigma 70-200mm f2.8 HSM II
Sigma 30mm f1.4
I am looking for recommendations on what lens I could get to replace the 35-70mm which is faster and/or sharper.
Previously I had a Tamron 17-50mm f2.8 which I sold as I found I was using it either at 17mm or 50mm, anything in between I would switch to the 30mm. There was nothing wrong with the lens, it was perfectly sharp and contrasty, just found it lacking in use. But now I am considering a faster lens to replace the 35-70mm
Do I even need something to fill this imaginary hole? Is my 30mm prime enough?
Lenses I have thought about are:
50mm prime - small, fast, light, cheapish but not that different from 30mm prime, no zoom
24-60mm f2.8 sigma - fast, cheapish but large and heavy
24-70mm f2.8 sigma - good range, fast but even larger and heavier and expensive
28-70mm f2.8 sigma - fast but big heavy and range is so so
17-70mm f2.8-4 sigma - seems good balance, but will i use it with all that other glass around?
17-70mm f4 pentax - also good, but a little slow and expensive
18-135mm WR pentax - big range and WR but slow and not real cheap, but possibly a nice walk around/bad weather lens?
As you might notice I am a bit all over the place with this
Not sure what/if I want! Others thoughts and recommendations are welcome
