I have this lens, and I find that the conclusions of the "In-Depth Review" regarding image sharpness are way off the mark. On my copy, 40mm is the strongest focal length of this lens, with solid overall sharpness across the frame even wide open. However at 20mm, the corners are softer wide open while the center is decently sharp. By F4, the corners have mostly caught up. By F5.6, the entire frame is very sharp. I'm not sure if this is due to sample variation or different testing methods, but in my opinion, this lens is a stunning performer as far as IQ goes. I mostly concur with the rest of the In-Depth Review, although I don't much care about the vignetting aspect. I tend to add vignetting in post to many of my pictures anyways.
It's worth mentioning, I tried VERY hard to find a reason to send this lens back for a refund. $900 is a lot of money for such a lens, and I was determined to be unhappy with it so I could get my money back and buy a Sigma 18-35mm F1.8 instead. I ended up being so satisfied with this lens, I've given up my intentions of getting that 18-35mm. You can read more of my impressions in the
lens database.
