01-06-2014, 10:45 AM   #1
audiobomber's Avatar
DXOMark - Best lenses for K-3
I've been waiting for this:
Best lenses for the 24-MPix Pentax K-3: Recommended primes and zooms - DxOMark
01-06-2014, 10:51 AM   #2
tomwil's Avatar
Strange that the older discontinued Pentax DA 18-250mm beats the newer Pentax DA 18-270mm in optical performance.
And, the cheaper Pentax DA 40mm XS beats the Pentax DA 40mm Limited in performance.
01-06-2014, 10:58 AM   #3
QuoteOriginally posted by tomwil Quote
Not so strange, since the Tamron 18-250mm is considered a slightly better lens than the later 18-270mm. I would still rather have the WR version.
How did they not review the DA 18-135mm WR? There was a note on their site that said the review was supposed to be available in October.
01-06-2014, 11:04 AM   #4
QuoteOriginally posted by audiobomber Quote
Is the 18-270 sealed? I didn't think it was.
01-06-2014, 11:09 AM   #5
I was surprised to see that the Pentax 55mm scored the same as Sigma 35mm Art. I'd say that is pretty impressive!
01-06-2014, 11:16 AM   #6
Sorry, you're right, the 18-270 is not sealed. It has much better CA's than the 18-250 according to DXO, same vignetting, and a little worse in sharpness, distortion and T-stop.
01-06-2014, 11:16 AM   #7
seventysixersfan's Avatar
I'm surprised how high up there the new DA 50mm f/1.8 is. Well above my trusty FA 50 f/1.4.
I'm also surprised by the showing of the kit lens DA 18-55 AL II-- it's listed higher than the DA 55-300, which I think is pretty sharp.
01-06-2014, 11:20 AM - 3 Likes   #8
boriscleto's Avatar
Laboratory measurbation that means nothing.
01-06-2014, 11:22 AM   #9
QuoteOriginally posted by seventysixersfan Quote
But what does one point difference in score mean? Particularly when you are comparing a kit to a consumer telephoto. I have never found DXO Mark lens scores particularly useful, except if you just look at the sharpness component.
01-06-2014, 11:23 AM   #10
On this page, it says that the DA 18-135 "will be tested and reviewed in January"
Tests and reviews for the lens Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR - DxOMark
01-06-2014, 11:25 AM   #11
I have a problem with the total scores on this one. I had a DA 40 Ltd and XS 40mm. The only noticeable IQ difference was the much higher fringing on the XS lens (CA of 11 vs. 6 according to DXO). I sold the XS 40, kept the Limited. Mechanically I preferred the Limited for its 49mm filter size and tiny lens hood. Size with either was not a factor for me, both are tiny.
01-06-2014, 11:28 AM   #12
They are saying the same about FA Ltd's for about a year Still not tested.
01-06-2014, 11:50 AM   #13
Even the sharpness measure is not that relevant, especially for zooms. I believe they are presenting the maximum sharpness achievable, at one focal length and optimum aperture. The 18-55mm is very sharp at 35mm, uneven across the frame at wide angle, and dead soft wide open at 55mm. As an owner of both, I would say the 55-300 is the sharper lens overall, at both ends and across the frame, but apparently not better than the 18-55 at its sharpest point.
What bothers me more is that they do not show that the DA*300 for example is sharper at f4 than the 55-300 at f8. At least other review sites give you a range of sharpness measures, not just a single, ham-fisted number.
01-06-2014, 01:06 PM   #14
causey's Avatar
Use manual focus at 55mm--mine suddenly became very sharp at 55mm once I tried focusing it manually. Otherwise, my copy displays the behavior you're describing: slightly decentered at 18-20mm, decently sharp across the frame from 22 to 28mm, very sharp betwen 28 and 40mm. At 55mm it isn't sharp unless focused manually.
01-06-2014, 04:44 PM   #15
They do measure sharpness in almost every aspect possible.
You have measures for every aperture (and main focal lengths for zooms) under the "measurements", and then "field test" tabs of a tested lens.
But oddly enough according to them the DA 55-300 is sharper wide-open at 300 than the DA*300 at F4, it must be a mistake !
dxomark, dxomark best lenses, k-3, k-mount, lenses, pentax lens, slr lens
Best flash for K-3 ArneTorp Pentax Camera and Field Accessories 18 04-20-2015 10:39 PM
K-3: Best Of The Best for 2013? Doundounba Pentax K-3 8 01-04-2014 08:06 PM
K-3 Review up on DXOmark Clarkey Pentax K-3 12 12-03-2013 08:38 PM
DxOMark - Best lenses for your Pentax K-50 NickLarsson Pentax SLR Lens Discussion 25 08-24-2013 07:59 AM
All times are GMT -7. The time now is 08:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
