01-07-2014, 06:54 PM   #1
Tamia's Avatar
Is it Too Risky Using 3rd Party Reverse Adapter?
When ordering something at Amazon, I needed to find something more to add to my order so it could qualify for free shipping, so I ordered a Fotodiox 10-LA-MR-PK-49 49MM reverse-mount adapter ring to mount a 50mm lens onto my K200d. I've never used a reverse-mount adapter before, but thought it would be a fun way to explore close-up shooting. Then, some time after placing my order, I read a review that warned about the adapter getting stuck on the camera. This was a little alarming, so I searched a bit more, including here on the forum, and saw where some others have had similar problems.
Now I'm not sure that I should risk trying this adapter. I don't want to do damage to the camera or the lens. Am I being too alarmist? If so, any tips on avoiding trouble? I'm sorry if the answer to this seems obvious, but I didn't find an answer when performing a forum search, though my searching strategy might have been flawed. Thanks for any advice. If I have to just trash the adapter, I'd rather have wasted about four dollars than ruin a camera or lens.
01-07-2014, 07:05 PM - 1 Like   #2
The adapters that typically get stuck are the infinity focusing M42 mount adapters, they have a little spring clip to hold them in the mount since the lock pin can't be used.
The reverse mount adapters are made like the non-infinity focusing adapters, they use the lock pin like normal and shouldn't get stuck. The only way I could see it getting stuck is if you somehow over rotate it in the mount, which is unlikely. I've got a cheap no-name reverse adapter and have never had a problem. I also have cheap infinity focusing M42 adapters, though I modified them to eliminate problems.
01-07-2014, 07:07 PM - 1 Like   #3
boriscleto's Avatar
A third party reverse adapter should not be overly risky.
https://www.pentaxforums.com/forums/54-pentax-lens-articles/152336-cheap-macr...lose-work.html
01-07-2014, 08:24 PM   #4
Tamia's Avatar
Thank you both for your quick replies, reassuring answers, and, Boris, the link. Much appreciated!
adapter, answer, camera, forum, k-mount, lens, pentax lens, slr lens
is it Risky to get a 3yr. old DA 50-135 Shanti Pentax SLR Lens Discussion 27 03-12-2013 07:32 PM
Buggy Q--FW or 3rd party adapter Shanti Pentax Mirrorless Cameras 4 03-11-2013 02:13 PM
Received my PK to Q adapter (3rd party of course) ve2vfd Pentax Q 12 11-15-2012 08:34 AM
DxO is adding support for 3rd Party Lenses kenafein Digital Processing, Software, and Printing 12 06-02-2012 01:59 PM
Wanted - Acquired: K-5 D-BG4 grip (3rd party grips may be ok too) Joojoo Sold Items 3 12-08-2011 11:40 AM
All times are GMT -7. The time now is 07:58 AM. | See also: NikonForums.com, part of our network of photo forums!
