Don't ever use filter as a subtitution for a true macro glass, it would destroy the whole experience (especially with cheap fitler)
. If you're on a budget, use bellows, extension ring, or reverse adapter to get high magnification. For macro, if you want to get close to the subject, then the 35/50 would be good. If you want to comfortably shoot at further distance, the 100mm is the one. Personally, I would get a manual macro if you plan to get either the 50 or 100. It's cheaper (no IQ suffering, however).
If you feel the 135mm is too short, then DA* 200 is your answer. And what Kenny said for the 77.
