The f/3.5 k-mount Pentax wide-angles are extremely sharp wide open. The K 28mm is better than the M, but not because it's sharper, but is also much bigger and heavier. The K 35/3.5 is also superb. The 35mm choices in the M series are f/2 and f/2.8, both are quite rare but the f/2 is very good indeed. If you can get one, that would be my recommendation. 35mm will rule out any really wide shots, but I find 35mm a much more useable focal length in general.
I would also recommend fitting a small 50mm lens in too, perhaps an M 50/1.7. It won't add much space or weight to your kit and will give you much more flexibility.
