01-18-2014, 09:38 AM   #1
which wide angle lens
I have a pentax k7 I only have pentax lenses and I am looking for only pentax wide angle for landscapes with so many to choose from looking for some guidance. thanks.
01-18-2014, 10:06 AM - 1 Like   #2
Aristophanes's Avatar
Da 15
01-18-2014, 10:18 AM   #3
Canada_Rockies's Avatar
I am very happy with my DA 12-24. It is a very good lens. Check out my Flickr site for a set of samples.
01-18-2014, 10:31 AM   #4
QuoteOriginally posted by Canada_Rockies Quote
+1. Versatile and great reputation for IQ.
01-18-2014, 10:34 AM   #5
QuoteOriginally posted by samattlfd Quote
I have a pentax k7 I only have pentax lenses and I am looking for a wide angle for landscapes with so many to choose from looking for some guidance. thanks.
Does that mean you want only Pentax lenses? Or just that that's all you have so far?
I have the older/slower 10-20mm sigma, and am pretty happy with it after finally getting a decent copy. By all accounts the 8-16mm sigma is sharper, but if you want one of those it appears they're getting hard to find in Pentax mounts. I'm sure 8mm would be preferable to 10mm, but I'm also sure that 10mm is preferable to 12mm. I probably wouldn't sacrifice 2mm for better optical performance, because for me the sigma is "good enough" for now. I only use it at smaller apertures, because almost inevitably you have very close and very distant objects in the frame, and while you get a lot of depth of field with wide lenses, you tend to need it, too.
01-18-2014, 10:54 AM   #6
QuoteOriginally posted by tibbitts Quote
Just pentax lenses thank you.
01-18-2014, 10:55 AM - 1 Like   #7
sterretje's Avatar
You do not need extreme wide angle for landscape. Unless you want those mountains in the background to be really tiny instead of as impressive as they are.
Why you Need a Telephoto Zoom Lens for Landscape Photography - Digital Photography School
01-18-2014, 11:14 AM - 1 Like   #8
waterfall's Avatar
Depends on subject. DA 15 is great if the subject is not at infinity. If infinity, then a telephoto zoom or telephoto prime emphasizes the size of the distant subject. I have no mountains locally, so the DA15 is my favorite landscape lens.
01-18-2014, 11:33 AM   #9
SpecialK's Avatar
+ 1 on the 12-24. Lots of flexibility. Wider than the 15, longer than the 21 :-)
01-18-2014, 12:22 PM   #10
I would first start with the lenses that you currently have and stitch. You can use Microsoft ICE for free.
01-19-2014, 12:41 PM   #11
KevinR's Avatar
For single shot landscapes, DA-15 ltd and Sigma 10-20 are both very useful and produce good IQ for the UWA range. DA-15 is also very flare resistant for shooting into the sun.
But as @interested_observer has pointed out, stitching might be a very good way to start with wide landscapes assuming they have nothing moving in them. You also can get much higher resolution this way than the default of your camera if you wish to print larger posters.
Can also recommend Hugin for stitching. DA-35 f2.4 is a fine lens and FL for stitching landscapes, but focal length above this is viable.
angle, k-mount, pentax, pentax k wide lens, pentax lens, slr lens
Which zoom lens are good for wide angle? fr3nzy Pentax SLR Lens Discussion 14 12-21-2012 09:47 AM
Ultra Wide Angle lens- Which one ? taiweitai Pentax SLR Lens Discussion 31 02-18-2011 02:45 AM
Which wide angle zoom lens duke peterson Pentax SLR Lens Discussion 3 02-22-2010 11:26 AM
Which wide angle lens to bye lduncan14 Troubleshooting and Beginner Help 36 05-18-2009 05:09 AM
Which wide angle lens? Darius4522 Pentax SLR Lens Discussion 15 03-20-2009 07:12 PM
All times are GMT -7. The time now is 06:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
