01-23-2014, 06:08 PM   #16
Ikarus's Avatar
QuoteOriginally posted by civiletti Quote
If you are not after bokeh, the A50/2.8 is super-sharp close up.
What's wrong with its bokeh?
01-24-2014, 12:07 AM   #17
QuoteOriginally posted by Ikarus Quote
Nothing wrong with the A50/2.8 bokeh, but the maximum aperture limits shallow depth of field when background separation is not as great as in your image.
01-24-2014, 02:04 PM - 1 Like   #18
Ikarus's Avatar
The OP was asking about a "bargain lens for close up of flowers". I'd say at close distances, background separation is the least of our problems. With a 50mm lens on APS-C and a focus distance of 40cm, the DOF is down to 1cm at f/2.8.
01-25-2014, 12:01 AM   #19
DOF is shallow, but there is out of focus and there is really out of focus. It often looks good when the background dissolves into color washes. Now, if maximum detail is desired, the A50/2.8 will beat the A50/1.4 at any focal distance, especially close up.
The A50/1.4 is hardly an expensive lens, but it is quite useful for shallow DOF close ups as well as for portraits and general photography. It is well built and not too large for a fast lens.
It seems the OP wants autofocus, though, so neither will fit the bill.
01-25-2014, 06:36 AM   #20
fevbusch's Avatar
Guys, when I said "bargain lens" I meant the new $200. Pentax DA35mm 2.4 vs the new DA50mm 1.8 $200. lens. Sorry if I confused anyone. I'm trying to find out if I will get better IQ and bokeh using the new 50 vs the new 35.
Freddy
01-25-2014, 01:44 PM   #21
sterretje's Avatar
QuoteOriginally posted by fevbusch Quote
You can look in th sample database whose bokeh you like better; quite sure you can find some bokeh shots there. But as I said previously, you will not gain magnification.
01-26-2014, 04:12 AM   #22
fevbusch's Avatar
Not sure what you mean by "will not gain magnification". I can get within 20" of a flower I'm shooting and if that leaves too much space around the subject I can always crop the edges.
After all, on my K30 body I'm getting very high resolution which should be more than adequate to result in a very high quality shot.
All I'm looking for is the good sharpness I get from the 35mm 2.4 and hopefully a slightly better bokeh. I would then consider it an acceptable replacement for my Sigma 50mm EX Macro lens.
Some of the comments I have gotten is that bokeh fom the 50mm 1.8 will be very good. Freddy
01-26-2014, 04:39 PM   #23
Ikarus's Avatar
The 50/1.8 would certainly be less of a compromise for close-ups than the 35/2.4, but since bokeh is a function of background separation, which in turn is a function of the subject distance, I would venture to guess that your cropped 50/1.8 shots would struggle to match the appeal of those from the Sigma Macro in many cases, even without considering the resolution loss.
01-26-2014, 05:03 PM   #24
fevbusch's Avatar
Thank you, Icarus and everyone else who helped me with this. I've decided I'll have my family buy me the DA50mm 1.8 in March (my birthday). Then If I decide I'm better off with the DA50mm 1.8 I'll sell the Sigma.
I do love the small size and weight of the Pentax. It fits so easily in my camera bag with my DA55-300. Then I'll just use my DA35mm for family shots, because it works so well indoors with its wide angle and great low light
performance (I hate to use flash unless really necessary). Freddy
01-26-2014, 06:49 PM   #25
mee
One other thought.. have you considered using Extension tubes with your current lenses?
You can get a cheap set of manual focus ones for... cheap hehe.. and it will give you macro-like focusing. That with the Catch-In-Focus would likely work nicely.
50mm, 50mm 1.8 plastic, da, da35mm 2.4 plastic, distance, k-mount, lens, lens vs da, pentax da35mm, pentax lens, plastic lens vs, slr lens, vs da 50mm
Swapping out the plastic mount on a DA 35/2.4? Fat Albert Pentax SLR Lens Discussion 5 09-27-2013 12:59 PM
Sigma EX DG Macro 24-70mm f/2.8 Lens vs Pentax SMC DA 16-50mm f/2.8 Lens VGC anthonyreid Pentax SLR Lens Discussion 10 05-14-2013 04:34 AM
DA 35mm/2.4 - A Plastic Wonder! -- DAL35 vs FA35 vs DA35m vs A35 (many photos!) frank Pentax SLR Lens Discussion 141 01-10-2013 10:26 AM
Pentax DA 50mm/1.8 vs. FA 50mm/1.4 vs. F 50mm/1.7 lukelbd Pentax SLR Lens Discussion 35 01-05-2013 06:33 PM
Plastic Fantastic VS 35mm 2.8 Ltd. DominicVII Pentax SLR Lens Discussion 13 01-04-2013 09:29 AM
All times are GMT -7. The time now is 03:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
