01-26-2014, 11:31 AM   #1
jerryleejr's Avatar
100mm macro overkill?
Done a lot of research and the Pentax 100mm macro keeps coming to the top. Looking to shoot some miniature models indoors. Some individually and some in groups. Just curious as to usability in tight spaces...
JJ
01-26-2014, 11:39 AM   #2
boriscleto's Avatar
The longer the focal length the longer the working distance. In tight spaces a 50mm or even the 35mm Ltd might be better. You might even be able to use a lens you already have with a Raynox adapter.
https://www.pentaxforums.com/forums/54-pentax-lens-articles/152336-cheap-macr...lose-work.html
01-26-2014, 12:10 PM   #3
QuoteOriginally posted by jerryleejr Quote
JJ
For tight spaces I'd go with a 50mm most likely, but it really depends on how much room you have to work with. The 35mm requires you to be way to close for 1:1 IMO.
01-26-2014, 12:57 PM   #4
jerryleejr's Avatar
Basically a table in my living room, depending on how many models or scenes I want to get in frame determines the room I have to work with...
JJ
01-26-2014, 12:59 PM   #5
dms
I think Boriscleto's suggestion makes most sense.
If you are shooting models you presumably are not at high magnification. If the models are, for example, about 4", you need about magnification 0.25, and I would guess 35-50mm macro is more likely the range you need.
Try what lenses you have, and if none are even close, get an extension set (if you have lens w/ aperture ring any K set will work) or an inexpensive set of diopters (often +1,+2, +3 or +4), or the Rayonox. And then you can work out what the effective FL, and then buy the macro lens, if the quality is not good enough (and f/11 for example what you have might be fine),
01-26-2014, 01:01 PM   #6
jerryleejr's Avatar
QuoteOriginally posted by dms Quote
I think Boriscleto's suggestion makes most sense. If you are shooting models you presumably are not at high magnification. If the models are, for example, about 4", you need about magnification 0.25, and I would guess 35-50mm macro is more likely the range you need.
But my suggestion is you try what lenses you have, and if none are even close, get an extension set (if you have lens w/ aperture ring any K set will work) or an inexpensive set of diopters (often +1,+2, +3 or +4). And then you can work out what the effective FL, and then buy the macro lens, if the quality is not good enough (and f/11 for example what you have might be fine),
Already on it, will post some results with what I have...
JJ
01-26-2014, 02:11 PM   #7
Don't forget the lowly 18-55 kit lens has a close focus range similar to the old zoom lenses of yesteryear which were often duriously labeled as "macro". Not a true macro in either case, just suggesting you give that a try.
01-26-2014, 02:43 PM   #8
If you're mainly going to be indoors, the Sigma EX DG 70mm f2.8 Macro is amazingly sharp and can be used in tight spaces.
01-26-2014, 03:29 PM   #9
Not a Number's Avatar
If space is tight you don't want to use a 100mm. I find a 100mm too long to use inside a greenhouse where there is only 18-24 inches between benches.
However if you want to take close-up detail shots the longer subject to lens distance makes lighting easier.
01-26-2014, 04:06 PM   #10
Kona's Avatar
I have a 90mm (Tamron) and 50mm (FA 2.8 Macro) and find both good for shooting figures. The 50mm is more flexible though, I think. The 90 is best for getting in real close, but for capturing entire 1/8 scale figures, I have to be about two meters away.
01-26-2014, 04:39 PM   #11
SpecialK's Avatar
I used a Tamron 90 on these. They are about 2-3 inches high.
These might be little bigger.
01-26-2014, 04:56 PM   #12
jerryleejr's Avatar
I would say that's average size or smaller for what I'm doing. There is just a lot of detail on models...
JJ
01-26-2014, 05:13 PM   #13
dms
In close up the depth of field is dependent on magnification, not FL; however, perspective issues are similar to ordinary photography. A long FL means greater distance and thus flatter looking, a shorter FL means closer and thus more "roundness" and areas closest to lens are relatively larger--just like in portrait photography.
01-26-2014, 07:09 PM   #14
mee
Small figures in a living room.. I don't think the 100mm Macro is going to be an issue at 1:1
I regularly shoot with a Sigma 105mm macro and have never been in the situation where I felt I couldn't get close enough.. even indoors shooting in my small living room. I'm about 7 or so inches away from my subjects IIRC. If anything, I've wanted MORE space between me and my subjects.
In any case, I wouldn't worry about Minimum Focusing Distance over Working Distance. If I understand this correctly, MFD is the space between the sensor and your subject while the WD is the space between the end of the lens and your subject.
Also, I would agree with the sentiment shown here that a macro focal length below 50mm is probably going to be too close -- You must also think lighting and if you are using (as example) a 35mm macro, then I am afraid the working distance could be a bit tight for proper lighting.
01-26-2014, 09:13 PM   #15
carrrlangas's Avatar
How is it nobody suggested the excelent and cheap M50 f/4 MACRO 1:2 yet? Full manual lens with great sharpness (contrast a little lacking like most old lenses). Ithink it sells for arround U$80 in the marketplace... Really good place to start.
100mm, 100mm macro, k-mount, macro, pentax lens, slr lens
Is it overkill to own both the DA 33m F2.8 Macro Limited & FA 31mm f1.8 Limited Lens kraigg007 Pentax SLR Lens Discussion 20 12-12-2013 07:58 PM
MAcro short filmed on Pentax-A 100mm macro metaphiston Video and Pentax HDSLRs 7 09-16-2013 11:58 AM
Pentax F-100mm f2.8 macro vs Pentax D FA-100mm f2.8 macro WR pentaz Pentax SLR Lens Discussion 8 07-03-2013 06:22 AM
Wanted - Acquired: Tamron 90mm macro / Sigma 105 ex dg macro / Pentax 100mm macro pentakxian Sold Items 6 05-31-2013 09:58 AM
Reverse stacking for macro onto a 100mm macro lens - 28mm good? GibbyTheMole Pentax SLR Lens Discussion 10 04-27-2012 02:56 AM
All times are GMT -7. The time now is 02:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
