Originally posted by Deni You can still try out the trick using a string to supplement a tripod. unfortunately I can't find the post but what you do is:
Find a screw that fits in the tripod mount underneath your camera.
Tie a string to it. The length of the string should be about the same length from your chin to the floor.
Tie another screw to the bottom of the string.
The idea is that while taking the photo you step on the bottom string (the screw in the bottom helps in getting a firmer hold) that is attached to the camera and stretch the string (that's why the string should be about the length from your chin to the floor). This should give you a couple of extra stops.
You need to practice with it though.
Also you don't need super expensive lenses. Just get an old manual focus 28 f/2.8 or something wider and faster. You don't need the fast af in those situations. That coupled with high iso.
What camera do you have? I'd be very comfortable using iso 3200 with the k100d as long as you overexpose the shot a bit. Well it also depends on how big you're going to print them.
I actually know an art historian who used that trick throughout the eighties and nineties. He said he mostly got away with it, but did have some museum guards object to it. I don't quite understand why; if the purpose of prohibiting tripods is to avoid accidents, then I don't see why a string should pose any threat. I think I will try my own luck at that trick.
To answer your question, I have a K100D. Maybe it's the lens I have, but ISO 3200 does not produce desirable results on it. You're right, I don't need fast AF and usually focus manually anyway. I'd really like something faster than 2.8, though. If it's true that the Sigma 20mm f/1.8 is only good after 2.8, then that's a real shame.
