01-29-2014, 03:18 AM   #1
different exposure different aperture problem
I get wrong exposures on different aperture setting. At f2.8 i get a correct exposure. Stopped down i get different values, at f4.5 is the most overexposed. I stop down to f8 still overexposed but less then at f4.5. Is it a sticky aperture lever?
(Details: Pentax K-30, 40mm Xs, settings: Bracketing off, Multi segment metering, AF+AE linking off, AV, TAV or M mode.)
01-29-2014, 03:26 AM   #2
is it a manual or auto lens?
01-29-2014, 03:28 AM   #3
it is DA 40mm Xs
01-29-2014, 04:57 AM   #4
Overexposure is about +1EV at f4.5. I appreciate any help and idea.
01-29-2014, 05:16 AM   #5
Put your camera into manual mode with shutter on B, try all apertures while looking at front of lens and you should be able to see if it stopping down correctly.
01-29-2014, 06:04 AM   #6
Ray-uk, i've tried but i can't tell if it's correct, the blades look ok.
The images from f2.8 to f6.3, they aren't much different further.
I get the same results in live view fix ISO or fix shutter speed.
2.8
4.5 Overexposure
01-29-2014, 08:18 AM   #7
I bought two new Pentax cameras with two new lenses in all. Three of four pieces had defects.
Pentax repaired my first camera in 3 months, meanwhile also scratched both the lens and body.
01-29-2014, 08:38 AM - 1 Like   #8
QuoteOriginally posted by angevoi Quote
I bought two new Pentax cameras with two new lenses in all. Three of four pieces had defects. Thanks consumer society.
I'm not exulted to send it to Pentax, they repaired my first camera for 94 days and i got back it with scratches.
With the results you have shown it is difficult to determine what the fault is, it could be either the lens or the camera body.
The only way you can really tell is to try a different lens on the camera body, If this cures the problem then you know it's the lens at fault, if it doesn't then it's the camera.
aperture, exposure, f4.5, k-mount, pentax lens, slr lens, sticky aperture exposure
Could Different Sensors Be Compared To Different Films? rbefly Pentax DSLR Discussion 6 01-15-2014 06:36 AM
Same settings, different lens, totally different results? Julie Troubleshooting and Beginner Help 27 07-03-2013 04:23 PM
Abstract Different views and different approach Velja Photo Critique 7 04-11-2012 04:05 PM
Abstract Different views and different approach Velja Post Your Photos! 5 04-11-2012 04:59 AM
AF adjustment problem. Different corners, different focus results. Saul Pentax SLR Lens Discussion 3 03-22-2009 06:50 PM
All times are GMT -7. The time now is 06:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
