01-30-2014, 12:12 PM   #1
schnitzer79's Avatar
Samyang really tight fit
I just bought a Samyang 8mm f/3.5 for my K-50 and apparently it has a very tight fit when mounting it on the camera. all my other lenses are a breeze to rotate and lock into place but this one needs a bit of a push.
i cant hear it grinding against anything but im just worried long term if it will create any problems.
has anyone else experienced this and if so, is there anything that could be done of will it be fine?
01-30-2014, 12:15 PM   #2
mrNewt's Avatar
I don't have this specific lens, but I do have a few lenses that are a tighter fit then the others and so far I never had any issues with anything.
01-30-2014, 12:53 PM   #3
kiwi_jono's Avatar
My Bower 85 f1.4 was unbelievably tight when I got it. Was worried to start with but with a bit of use it has loosened to a more believable level.
I'm guessing their mount tolerances are not as tight as some other manufacturers. On the other hand the lens is a real winner. So happy with it, I would not want to send it back!
01-30-2014, 01:17 PM   #4
EarlVonTapia's Avatar
Did you buy it used? A tight mount could be evidence of a drop, which could mean misaligned elements resulting in poorer image quality. If so, contact the seller and ask for the history of the lens.
01-30-2014, 01:19 PM   #5
Thanks for the replies guys. No i bought the lens new actually. Maybe it will loosen a bit over time then
01-30-2014, 01:37 PM   #6
Na Horuk's Avatar
I think most new lenses have a tighter fit, which loosens up. The machining on a Samyang might also not be as precise as on a genuine Pentax.
Also, do your other lenses have a plastic mount? Plastic mounts are generally not tight and are easy to slide on.
If this problem doesn't go away after a week of usage or if the lens leaves scratches on the camera mount, then you have a problem.
01-30-2014, 02:40 PM   #7
QuoteOriginally posted by kiwi_jono Quote
The same with my Rokinon. I wouldn't worry about it too much mine has worn in about right.
It's standard industry practice to make one side of the mating surface softer than the other and in this case you can bet it's on the lens side.
01-30-2014, 03:13 PM   #8
oxidized's Avatar
When I first got my sigma 10-20 it was also super tight. Now is totally normal. I've had it for years and no problems.
01-31-2014, 04:17 PM   #9
Otis Memorial Pentaxian
My Rokinon 8/3.5 Fisheye (essentially the same as the Samyang) is also a pretty tight fit, though there is no grinding.
k-mount, pentax lens, samyang, slr lens
Nature Wrapped up tight RobG Post Your Photos! 17 11-23-2013 02:42 AM
Samyang/Rokinon 85mm - is it really f1.4 lens? yusuf Pentax SLR Lens Discussion 5 04-10-2013 07:38 PM
Macro Tight Fit eaglem Post Your Photos! 2 08-19-2010 02:46 AM
DA WR lens hoods fit way too tight? future_retro Pentax SLR Lens Discussion 17 08-03-2010 08:10 PM
K200D card cover tight fit Billy Batson Pentax DSLR Discussion 6 01-26-2009 06:15 PM
All times are GMT -7. The time now is 04:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
