Originally posted by MBK Hi
I've had a Pentax DA 70 mm F2.4 Limited for a couple of years now.
Very pleased with it.
I want to attach a filter to it - and the hood with extension is able to come off according to what I understand although I read it is 'built in'...
How?
It seems completely impossible to unscrew with a normal amount of force applied. I would hate to wreck it, and it would be terrible to think that I have misunderstood something (it really is NOT possible) and thus damaged it in the process.
Kind regards
Morten Bech Kristensen
Take a look in the database of reviews for this lens. I had exactly the same problem. I actually found that if you leave the lens cap on and grip the cap with your whole hand and twist, it comes off easier. Somewhat like using a jar opener to twist off a tight cap on a jar. Maybe this is just a quirk with my particular copy. I bought my lens used and it does not have a mark or scratch on it, absolutely pristine condition. I wonder if this problem of the lens hood locking on may be why the previous owner gave it up. One other thing, and it may be related. This lens has some play or wobble in the inner barrel. Since the lens is metal this wobble makes a clicking sound which makes it seem worse than it actually is. Also it is very much noticeable with the hood on, much less so with the hood off. I wonder if it is possible that whoever had this lens before me may have loosened up the inner barrel by twisting too hard to get it off. None of my other limiteds, 15 mm, 21 mm and 35 mm Macro have any inner barrel wobble at all.
The good news is that over time the hood on my DA70 mm may have went through a break in period as it now seems to go on and off much smoother and easier. I hope this helps.
