02-01-2014, 04:24 PM   #1
SLR lens on DLSR Camera
I own a Pentax ZX-60 with multiple Sigma lens. I have Sigma DL macro lens and a 28-80mm lens that came with the camera. Big quiestion...is will these lens work on the Pentax DSLR series? Any help please!
02-01-2014, 04:29 PM   #2
Julie's Avatar
Welcome to the forums!
Yes, they will work fine with any Pentax DSLR camera or the K01 Mirrorless. No modifications or adapters needed. You'll be able to use your lens in autofocus mode and you'll be able to control the aperture of the lens via the camera (when aperture ring is set in "A" position.
If you have any older manual focus lenses, those will also work, see the guide linked below for instructions.
---> https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/110658-using...x-dslrs-f.html
And differences and features of different Pentax series lenses, below.
---> http://www.mosphotos.com/PentaxLensesExplained.html
02-01-2014, 04:35 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by bvpd15 Quote
Absolutely. There is no loss of functionality at all with any lens that the Z series Pentaxes used. There are more lenses that will fit and work fine. The clues are the lens types. Your DSLR will be able to use DA, DA*, FA, D-FA, and F lenses for both autofocus and auto exposure. A lenses will work in auto exposure just fine, but they are manual focus lenses. M and K series lenses will only work in M (manual) exposure mode if you want to use them with any aperture other than wide open, when you can also use Av mode. The magic Pentax green button will set a shutter speed for you. Screw mount lenses work with an adapter, and obviously cannot auto focus. There is an elaborate sticky at the top of the beginners' forum that will get you on track for which lens will do what on your new DSLR.
02-01-2014, 04:39 PM   #4
tromboads's Avatar
Im surprised you don't just try these things. I mean.. If you have it there in front of you, you know It doesn't look much different
02-01-2014, 04:41 PM   #5
This is one reason that I'm so happy I chose Pentax! I had no idea, when I bought my k-x, just how backwards compatible everything is. I'm having a ball buying lenses from eBay & I'm sure if I put some effort into thrift stores & garage sales, I could find stuff there too.
02-01-2014, 04:56 PM   #6
Welcome to the Forum!!
Actually with a Pentax digital body, you will get enhanced functionality. What do I mean? Well there is focus confirmation - where as you use either your manual focus / or auto focus lenses, the camera body will tell you that the image is in focus and you can then shoot. Then there is catch in focus - where as the body determines the image is in focus, it will just capture the image auto-magically
02-01-2014, 06:15 PM   #7
Emperor and Senpai
VoiceOfReason's Avatar
I use some lenses that were made for film SLR cameras on my K5 quite a bit. I even have them in my signature. Now the funny one is that I've sued some fo my DSLR only lenses on film cameras with interesting results. You want wide? Strap on a Tamron 10-24 to an SF-1. It will not vignette after 12 or 13 mm or so.
02-01-2014, 06:25 PM   #8
JPT
Lenses from that era will work fine one a Pentax DSLR, even if they are from another brand. Another advantage with a DSLR is that they will be able to benefit from image stabilisation technology, so should be easier to shoot at low shutter speeds.
One thing to note is that the image will not be as wide as you are used to. For example, the 28-80 when set to 28mm on a DSLR will give you the same angle of view as when you have it set to 43mm on your film camera. So I recommend that you get a DSLR with a kit lens, because it does not cost much more. Kit lenses usually start at 18mm, which is close to the wide end of your 28-80.
02-01-2014, 07:45 PM   #9
If it will mount on a Pentax film camera a lens will mount on a Pentax dslr
02-01-2014, 09:39 PM   #10
SpecialK's Avatar
Backwards compatibility is large marketing point Pentax Ricoh apparently failed with :-)
02-01-2014, 09:43 PM   #11
Emperor and Senpai
One other thing, since modern sensors tend to out resolve lenses you may find your old lenses may not quite be as sharp as you remember.
02-01-2014, 10:00 PM   #12
tromboads's Avatar
*hugs his 1958 Tessar
(don't listen to the bad man. It's ok. It's ok)
02-03-2014, 03:38 PM   #13
45 Mike's Avatar
QuoteOriginally posted by mikemike Quote
I just found a lens by Sigma that will NOT mount on my Pentax K-x, however it WILL mount on my MX, P3n, P30t, and both Ricoh film bodies.
02-03-2014, 03:41 PM   #14
Huh. What markings does the lens have? Pics?
02-03-2014, 03:48 PM   #15
45 Mike's Avatar
I found a Sigma 28mm f:2.8 lens that mounts fine on all my K-mount film cameras, but will NOT mount on my K-x DSLR. I am getting ready to order a K-30 and am wondering if anyone can tell me why this won't mount. Can I do something to make it mount? will it mount on my K-30??
I am fairly certain that it also mounted on my ist*DL, but I do not have it here to test I gave it to my neice.
PENTAX K-x  Photo
PENTAX K-x  Photo
PENTAX K-x  Photo
PENTAX K-x  Photo
camera, k-mount, lens, pentax, pentax lens, sigma, slr lens, slr lense, slr to dslr
Pentax K-50 2 Lens Weatherproof DLSR Bundle 749.99 cwhans Pentax Price Watch 3 10-01-2013 03:13 PM
PENTAX K-30 lens-interchangeable digital SLR camera wins iF Product Design Award 2 ogunturkay Pentax News and Rumors 11 12-31-2012 07:29 AM
Using Film SLR Lens Filters On DSLR Lenses Racer X 69 Pentax SLR Lens Discussion 19 12-14-2012 03:16 PM
Older vintage camera straps on newer Digital SLR? Abstract Pentax Camera and Field Accessories 13 01-10-2011 05:39 PM
Old SLR Lens Work on DSLR Camera? TexasTom Pentax SLR Lens Discussion 9 11-04-2007 10:59 AM
All times are GMT -7. The time now is 10:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
