04-13-2008, 09:17 AM   #1
Raybo's Avatar
Anyone own this lens?
I just couldn't help myself and picked up this lens, tried the search function but could not come up with anything.
If anybody has any experience with, or owns this lens could you please share your thoughts.
I have a couple of birdfeeders about 70 feet from a good vantage point and have a very sturdy tripod and remote shutter release.
Will this rig get some decent images?
M42 MC MTO 11CA 10/1000mm lens astro and others T2 moun - eBay (item 140222257318 end time Apr-13-08 07:01:00 PDT)
Thanks in advance,
Ray
04-13-2008, 09:50 AM   #2
I don't know anything about that particular lens but it looks like a mirror lens and I generally don't recommend mirror lenses because they tend to produce very odd and distracting out-of-focus backgrounds (bokeh). Here's an article with an example of this:
Bokeh and Background Blur
You should be able to minimize this effect if you maximize your depth of field (use the smallest possible aperture). Have fun with your new lens and I'd love to see some pictures!
QuoteOriginally posted by Raybo Quote
Thanks in advance,
Ray
04-13-2008, 09:59 AM   #3
aegisphan's Avatar
Mirror lens does have its use. If you can go close enough, and there is not highlight in the background, a mirror can still produce a stunning picture. I've not gotte one yet cause I don't shoot much at 350 or 500. Of course you shouldn't expect ultimate sharpness with any of these lenses (probably the Mirotar is an exception).
04-13-2008, 10:18 AM   #4
Groundloop's Avatar
QuoteOriginally posted by Jun Park Quote
...maximize your depth of field (use the smallest possible aperture). Have fun with your new lens and I'd love to see some pictures!
Mirror lenses don't have variable apertures. The only way to control exposure is with shutter speed and/or ND filters, and ideally the filters would be mountable on the rear of the lens, since the front filter size would be huge.
04-13-2008, 10:22 AM   #5
Here is a site where you can buy one new from Russia:
MTO-11CA 10/1000 Telephoto Lens
Assuming that the performance is good, with the case and filter, you probably made out pretty good.
This lens and other MTO models are also sold through a number of outlets under the Rubinar name.
04-13-2008, 10:25 AM   #6
I forgot the note that there may be issues with mounting this lens on certain camera bodies. The body circumference is pretty large and may not clear the built-in flash on some modern slrs.
04-13-2008, 10:30 AM   #7
Moderator Emeritus
soon as I saw the listing that was my thought. Will this even fit under the flash? Lets hope so. When you get it, post some sample shots.
04-13-2008, 10:47 AM   #8
Raybo's Avatar
I already have the 500mm version of this lens and it fits no problem on my K100D Super, in fact I have zero issues hand holding with great results.
I have no problem with the bokeh, I just want to capture some birdies.
I'll post images after it arrives.
Thanks again,
Ray
k-mount, lens, pentax lens, slr lens
All times are GMT -7. The time now is 05:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
