02-04-2014, 02:39 PM   #1
Name this lens defect!
I have an old Focal (K-Mart) 80-200mm f/3.5 lens. The front element/group has a ragged, transparent, metallic band on the rim. I know it's not fungus. Are a couple of elements coming apart?
02-04-2014, 02:51 PM   #2
Can you post a pic??
02-04-2014, 03:05 PM   #3
Boris_Akunin's Avatar
Hard to say without a pic, could it be dried cleaning fluid or something like that? That stuff is quite hard to get off sometimes.
02-04-2014, 06:39 PM   #4
jimr-pdx's Avatar
Whatever it is, I shall name it "Tighelander" - congratulations!
02-05-2014, 12:25 AM   #5
In this photo the defect is reflecting the light. At other angles, it's transparent. It's on the inside of the element/group. It's around the rim of the glass like a ragged fringe.
02-05-2014, 04:00 AM   #6
Lloydy's Avatar
Possibly oil from separating helicoid grease that is creeping on to the elements ? or maybe schneideritis - where the black paint around the edge of an element degrades and lets light in through the edge, but that is usually more whitish spots?
02-05-2014, 04:08 AM   #7
It would to have a lens diagram, is that a kitted group in front or just a single element?
You should be able to unscrew the retention ring around the front element/group and take it out for cleaning.
02-05-2014, 10:52 AM   #8
I had a 400mm lens with a very similar fault see here
Tele-Astranar 400mm F6.3 Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
pic in first review
The good news is that the effect on the pics wwas negligible.
I couldn't decide whether this was incipient separation of the doublet, or leakage/condensation of volatiles from the thread locking chemical (or st else..?). In any case I decided that any attempt to separate the doublet was more likely to cause damage than a fix.
02-05-2014, 01:50 PM - 1 Like   #9
6BQ5's Avatar
Based on the picture I would say it looks like cleaning fluid that seeped in from the top of the front element and never dried. If it did dry then it left some goop behind. Seeing that it is on the very outer edge of the glass I wouldn't worry about it. Even if it were haze in the center then the worst that happens is a loss of contrast. You would probably notice it in that case when shooting uniformly lit flat subjects of one color. In real life situations with varying colors and contrasts you probably won't notice a thing. Since it's off the edges I think you won't notice anything anyways.
k-mount, lens, name this lens, pentax lens, slr lens
What could be causing this defect? Jamey777 Pentax Film SLR Discussion 4 12-20-2013 09:26 AM
Should I buy this lens ? Possible defect... opianstate Pentax SLR Lens Discussion 8 09-04-2010 04:56 AM
Is this a sensor defect? tfischer Troubleshooting and Beginner Help 7 08-30-2010 09:08 AM
What keyword to search lens name in this forum? quaker Pentax SLR Lens Discussion 3 11-10-2009 11:59 AM
Anyone use this lens? The price is calling my name... JRock Pentax SLR Lens Discussion 11 01-17-2009 07:23 PM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
