Originally posted by mk07138 I don't want a huge set of lenses and this seemed to me like a good collection covering a fairly standard range.
Thanks for any input! I know this topic has been covered to death already.
I'm with you, there. As many tempting choices as there are out there, I still don't want lenses running out of my ears, either.
Yeah, the topic gets covered over and over again, but everybody's different and what may work for one person may not work for another. Around here, you've got a wide variety of shooting styles, as well as budgets, so everybody needs a roadmap that will work in terms of both their budget and shooting style.
Since you like macro--it would depend on what type of macro shooting you do. Do you shoot mostly static things like flowers or do you like to shoot bugs, lizards, and other little critters?
For the 30s range, I would say go for the DA35, as it seems to be the most versatile lens of the 3. Take a look at the other threads for the DA35 and look at the examples. It has excellent IQ both close up and further away. If you're more concerned about being able to shoot in low light, then get either the 31 or the FA35 since they both have wider apertures than the DA35.
Between the 50 and 90mm macros, get the 90. If you have both the 35 and 90 macros, you'll be prepared for just about anything macro you might run into.
I like the idea of the 70-200/2.8+TC. If I used that focal range more often then I do, I might consider it for myself.
HTH,
Heather
