02-08-2014, 09:23 AM   #1
lguckert79's Avatar
Pentax 50-135 or Tamron 70-200 for weddings
Pentax 50-135 or Tamron 70-200 what one would you use for weddings they both are highly regarded but what one would you prefer and why do you prefer the lens of choice??
02-08-2014, 09:40 AM   #2
aleonx3's Avatar
my preference is the 50-135 focal length... as you can get closer to the action.
02-08-2014, 09:42 AM   #3
crewl1's Avatar
In a church you will not be heard using the Da* and K-5.
The Tamron may be a bit noisier.
02-08-2014, 09:46 AM   #4
lguckert79's Avatar
QuoteOriginally posted by crewl1 Quote
that is what I was thinking to and I get the WR also
02-08-2014, 09:54 AM   #5
MadMathMind's Avatar
QuoteOriginally posted by lguckert79 Quote
Do you expect it to rain inside the church or reception hall?
The 50-135 is probably better because it's more compact and a bit easier to handle. You won't need the extra reach, so the lighter lens will be a blessing. The DA* is about a pound lighter than the Tamron.
02-08-2014, 09:55 AM   #6
I don't photograph weddings, but I'd guess the Pentax range and weight would be preferred, the only question would be whether you trust the SDM and/or are willing to rely entirely on manual focus. Probably if you're heavily into weddings you'd have at least two of everything for redundancy anyway, so maybe the question would be two 50-135s vs. something else. I'm thinking screw drive in general would be less preferred for weddings, just due to the noise.
02-08-2014, 10:00 AM   #7
I will suggest 70-200, not only it will provide you a better subject isolation for wedding portraits but let you capture it from comfortable distance. Having owned both, I don't think 70-200 is noisier to be objected in church. AF speed is same even though 70-200 has screw drive.
02-08-2014, 10:02 AM   #8
StephenHampshire's Avatar
Another suggestion - a used Sigma 50-150 f2.8 - HSM is reliable and quiet, and the size is a great deal smaller than the Tamron 70-200, about the same size as the 50-135. Very sharp, although not WR
02-08-2014, 10:04 AM   #9
This screwdrive noise thing is really over saturated.
Unless you have to focus from one end to the other for 3 times, no one will notice!
02-08-2014, 10:09 AM   #10
lguckert79's Avatar
QuoteOriginally posted by StephenHampshire Quote
I have tried to find this lens and had no luck and the ones I do find they want to much for it. It must be a good lens because you never see it
02-08-2014, 10:33 AM   #11
It is an excellent lens. Mine is a bit battle scarred but still going, I got it for under half the price of the DA 50-135 (closeout sale when Sigma stopped making it) although of course it is not weather sealed, you do gain a little extra reach. The HSM is ultra quiet and smooth
PS I have the Tamron 70-200 also, it feels a lot bigger and heavier!
02-08-2014, 11:57 AM   #12
lguckert79's Avatar
well I ended up getting the tamron 70-200 and got a tamron 17-50 so I think I made the right decision and thank you for all your help with my issues
02-16-2014, 04:22 PM   #13
slip's Avatar
I also would take the 50-135 2.8 as the 70mm end on the 70-200mm might be too close for some situations...all you need to do is crop if you are not close enough
I have the Sigma 70 - 200mm and it is very heavy to use all day long.
Good luck with your choice
Randy
02-17-2014, 09:01 AM   #14
Is it me or does the price for the 50-135 just seem way to expensive compared to similar lenses??? I mean I know it's a great lens to have in your bag but for the price...wow. You can get the same quality with the Pentax 60-250 for the same price. Sure you will lose a stop but you will gain reach and versatility....and about 12 ounces (340 grams) but it is lighter than the Tamron 70-200 at 2.5 lbs
02-17-2014, 11:09 AM   #15
bdery's Avatar
50mm will be more useful than 200mm in most wedding situations. So I'd go with the 50-135.
k-mount, pentax, pentax lens, slr lens, tamron, weddings
FA* 80-200 or DA* 60-250 or DA* 50-135+ Tamron 70-200/2.8 malakola Pentax SLR Lens Discussion 19 11-09-2013 06:31 AM
The other LBA (Lens Buying Advice) Tamron/Sigma 70-200, Pentax 50-135, or 60-250? JinDesu Pentax SLR Lens Discussion 7 08-22-2011 10:42 AM
Tamron 70-200 or Pentax 50-135 in sharpness LeDave Pentax SLR Lens Discussion 12 11-15-2009 09:53 PM
Pentax 50-135 or Tamron 70-200 f2.8 RonMexico Pentax SLR Lens Discussion 18 01-21-2009 02:45 AM
Tamron/Sigma 70-200 or Pentax 50-135? Clem Nichols Pentax SLR Lens Discussion 6 09-26-2008 07:07 PM
All times are GMT -7. The time now is 02:08 PM. | See also: NikonForums.com, part of our network of photo forums!
