04-14-2008, 10:59 AM   #1
Scout Pro's Avatar
Tamron 28-75mm f/2.8 Focusing Issue
I have had this lens now for maybe 3-4 months and I have been noticing that it apears not as sharp as many of the sample I have seen here in the message boards. I have a K10D, generally use program mode for general shooting and center-point focusing, etc. I understand the issues with the cameras in-camera jpeg compression processing, but this seems excessive. My Tamron 18-250mm puts out sharper image than this currently.
What sort of tests can I preform to check for focusing problems (fron-back focus)? Photo examples attached.
Any info will be greatly appreciated.
Thanks
04-14-2008, 11:17 AM   #2
i performed several tests on my lens and posted up the results on this forum, except that was about 6 months ago and i deleted them all. But here are a few suggestions: you could take a picture of a ruler. What you would do is place the ruler on a table, stand at one end of the ruler - this is the position that you will test your lens. Then, zoom in close enough so that you see maybe 4-6 inches that spans the length of the frame. Take a picture, at a 45 degree angle to the ruler. Focus on a number, and take a picture. It would help to use a tripod. open the aperture to 2.8. and use the 2 second timer to release the shutter. That way, it would eliminate any human-related shaking. When you pull up the image on a computer, the number you focused on should be sharp, and the numbers away from it should be blurred.
When i did this test, i focused on the '6', and when i pulled up the image on a computer, the number '8' was sharp....
04-15-2008, 10:43 AM   #3
Scout Pro's Avatar
Ting,
Thanks for the help, I will try this out soon. What did you do about your issue, etc.???
04-15-2008, 07:46 PM   #4
oh man, that is a long story. in short: i bought the lens over ebay, it is from japan. so i sent it back, then it was returned good as new. had to pay shipping twice. but that was, like a said half a year ago, and the lens is still amazing, no regrets.
k-mount, pentax lens, slr lens, tamron, tamron 28-75mm f/2.8
Tamron 17-50mm, Tamron 28-75mm, Sigma 17-70mm, which lens for my trip to Greece? macky112 Pentax SLR Lens Discussion 15 11-20-2011 03:08 PM
Tamron 28-75mm & 70-200mm focusing speed yusuf Pentax SLR Lens Discussion 23 11-11-2010 02:12 PM
lens comparison- fa50mm / tamron 17-50mm / tamron 28-75mm bimjo Pentax SLR Lens Discussion 11 03-16-2010 01:10 AM
Front-back focusing issue Mystic Pentax DSLR Discussion 10 08-26-2009 08:15 PM
Focusing issue? OrenMc Photographic Technique 16 05-07-2008 01:28 AM
All times are GMT -7. The time now is 07:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
