Originally posted by Rafalas Hi everyone!!
Today finally the Super-Multi-Coated Takumar 50 f1.4 arrived! I've been trying it but I think I'm going to need a bit of your help :-S. I have a couple of problems that I hope you can help me with.
First, I mounted an original pentax M42 to K adapter on the K10D. Then, I screwed the Takumar on the adapter, until I can't do it anymore (I don't hear any 'click' sound or similar, it just stops).
Then, I turn on the K10D (I've the 1.30 firmware). It doesn't ask me anything, and I thought it will ask me which focal I have mounted: is that normal?
Then, I switch the camera to Manual Focus. When I focus, the focus confirmation doesn't work (the green hexagon, I thought it will): is that normal?
Any of the camera modes don't work (by that I mean there's no difference) but Manual mode, I already knew that. Therefore, I cannot use the light meter on the camera or nothing similar. To do a shot, my only solution is to "estimate" a shouter speed, do a test shot, and reiterate. The camera cannot give me any of the light mettering options, and that's quite a bad thing. Is that normal?
As well, working with the lens at 1.4, I found out that I needed very long exposition times (around 1/10) to take indoor shots next to a window with sunlight. I've been impressed because I thought that using so opened lenses will reduce noticeably the exposition times, but it's not the case. The kit 18/55 lens needs less exposition to take the image. Is that normal?
The camera stabilizer as well doesn't work, as the icon doesn't appear when I take photos. Is that normal?
Please, throw some light in here! If you see or think that I'm doing something wrong setting the camera or mounting the lens, please let me know!
The lens feels and looks awesome although. It's all metal and the focus ring is very smooth. The one I got is like new, and it really gives a nice feeling.
Thanks everyone for your help. Any advice or comment will be very appreciated.
Regards.
Welcome rafalas. because it's a screwmount, it's on when it can't turn anymore so that's ok. when you start, it asks for focal length, this is for EXIF recording and the SR. you must enable the Aperture and FI settings in the menu. this site describes for K100D, but similar for K10D
K100D (Super) Pictorial guide to using manual lenses [imgs] [Page 1]: Pentax SLR Talk Forum: Digital Photography Review
with an M42 lens, because there's no physical connection to the camera, metering is more complicated. first, set your lens to Manual, not Auto. you can use Av mode, by focusing first, selecting the aperture you want on the lens and then shoot. in Manual mode, focus, select aperture on the lens, then press the Green button and then shoot. for a "k" or "m" mount lens, you cannot use Av mode because the lens does not stop down until the shutter is triggered.
