02-15-2014, 08:48 AM   #1
malenisjaj's Avatar
Square plastic on the back of the lens?
I tried to google-it but I couldn't find anything about it.
I saw that some of the lenses on their rear end have square shape of plastic and some don't. I was wondering, is there any difference with image quality?
Square shape of plastic and usual shape.
Thank you all!
02-15-2014, 09:03 AM   #2
JinDesu's Avatar
Your sensor is technically a rectangle, not a circle. Therefore, projecting a rectangle from the lens is actually better than projecting a circle. This works especially well if the lens is intended for APS-C use only, as it cuts down in internal reflections within the mirror box.
02-15-2014, 09:33 AM   #3
Na Horuk's Avatar
So its like a secondary hood on the inside? This should protect from ghosting, sensor reflections, and loss of contrast due to light bouncing around the mirror box
02-15-2014, 09:39 AM   #4
QuoteOriginally posted by malenisjaj Quote
Thank you all!
What lens is that with the rectangular opening? It might be worth adding such a mask to old lenses for use on APS-C. Digital sensors are more shiny than film was, and the reflection can bounce off the back surface of the lens, which in old ones was not well coated. Gluing on a bit of black paper might improve contrast. An experiment is needed.
02-15-2014, 10:42 AM   #5
manacho2005's Avatar
Sigma DSLRs seem to have an element in front of the mirror. I wonder if someone could fashion something like that to a backup body to compare shots....
02-15-2014, 10:47 AM   #6
malenisjaj's Avatar
QuoteOriginally posted by clicksworth Quote
It's smc 135mm f2.5.
QuoteOriginally posted by manacho2005 Quote
That would be really interesting to know.
02-15-2014, 11:17 AM   #7
Thanks. I have both types of 135 F2.5 with M42 mount but they don't have the mask. Pentax must have thought it worthwhile. It might even be made a bit smaller for a crop sensor.
02-15-2014, 12:44 PM   #8
bluestringer's Avatar
The old Pentax 100mm f4 Macro has the rectangle opening also.
02-15-2014, 12:49 PM   #9
panoguy's Avatar
On Sigma DSLRs, that's the removable dust-protection/IR cut filter. I think they can be bought as spare parts from Sigma, but I'm not gonna touch the one on my camera!
02-15-2014, 01:04 PM   #10
scratchpaddy's Avatar
QuoteOriginally posted by panoguy Quote
Replacement units for the SD1 cost $60 in the U.S.. The ones the SD14 and SD15 use are only $30. I've taken mine off a couple of times for infrared photography. It just pops out, no tools required. It's fun, you should try it.
02-15-2014, 08:53 PM   #11
That would be neat if Pentax implemented that dust protector to their weather-sealed bodies. But improved in a way to protect the body from the elements regardless of what lens was used (sealed mirror box).
02-16-2014, 04:08 PM   #12
slip's Avatar
One fell out of my M 135 and it didn't seem to make any difference in image quality
Randy
k-mount, pentax lens, plastic, shape, slr lens, square
Pentax Da35mm 2.4 plastic lens vs Da 50mm 1.8 plastic lens fevbusch Pentax SLR Lens Discussion 24 01-26-2014 06:49 PM
what happen if i shoot with the "back" of the film instead of the "front" ? aurele Film Processing, Scanning, and Darkroom 20 07-03-2013 08:21 AM
Recondition the plastic on the lens barrel Gareth.Ig Pentax SLR Lens Discussion 7 05-30-2011 05:31 PM
Can the plastic lens mount on cheap Pentax lenses be replaced? creampuff Pentax SLR Lens Discussion 22 12-30-2010 06:29 PM
Those contacts on the back of a lens whitelotus9 Pentax SLR Lens Discussion 3 10-23-2010 08:51 PM
All times are GMT -7. The time now is 11:25 AM. | See also: NikonForums.com, part of our network of photo forums!
