02-17-2014, 07:55 AM   #1
malenisjaj's Avatar
67mm CPL on 52mm and 58mm lenses?
I ordered a 67mm CPL and few step up rings for lenses and now I'm thinking is it going to be problem with quality of image and with its (un)esthetic look? I mean, I don't mind putting bigger CPL on smaller lens but before few minutes I draw on a paper total sizes of 52mm, 58mm and 67mm and differences between 52mm and 67mm are gigantic.
Should I need to be worried or it's all silliness?
02-17-2014, 08:02 AM   #2
It looks goofy, but works fine. I do 62-58-55-52-49, because I only had money for 62's at the time. I am now acquiring 49's for the limiteds. At least you will being using rings, I often just hold the 62mm filter infront of my 49mm lenses, as needed.
I have not noticed any extra photo quality drop off other than the typical bit from having a CPL or ND piece of glass added. Just buy good filters and you won't notice much degradation.
02-17-2014, 12:34 PM   #3
Canada_Rockies's Avatar
I agree with Calculator1. The step rings won't be much of a problem, except for flare because you cannot put a hood on the front.
52mm, 52mm and 58mm, 58mm, 67mm cpl, cpl, cpl on 52mm, k-mount, pentax lens, slr lens
58mm and 52mm Reddaddy Visitors' Center 4 07-17-2012 10:09 AM
All times are GMT -7. The time now is 04:11 AM. | See also: NikonForums.com, part of our network of photo forums!
