Originally posted by malenisjaj Maybe the duel isn't right due to Tamron's older and everything is manually (except aperture ring) and on the other hand, smc is pretty new. But, the thing is I don't mind doing everything manually but if you look into IQ, is Tamron better then this cheap (but with good reviews in forum database) pentax?
Maybe you have another lens which is better and not that expencive for lens zoom to 300mm?
Kind regards.
I don't have either lens, but I've had five Pentax 55-300s and a Tamron 70-300 (used, but the current K-mount model, which isn't the current Tamron for other brands, of course.) I don't see why, for the same price, you wouldn't consider a used copy of the current Tamron AF model. The biggest advantage of the 55-300 vs. the Tamron is the 15mm at the low end, but you're not getting that with either of the choices you're listing, either. I have the Pentax 100-300F, and can tell you that 70-300 is a lot handier than 100-300.
