02-26-2014, 04:58 AM   #1
malenisjaj's Avatar
Can this be repaired?
I bought this lens before few weeks here (today I got it) and the only one I can blame for this issue is the customs (I sent a complaint). Nevertheless, it's SMC-A 35-105 f3.5 and I can berely put a cap.
Can this, somehow, be repared?
https://drive.google.com/folderview?id=0ByeW6kWG57WwMmszNHNhZXV5Vms&usp=sharing
02-26-2014, 05:07 AM - 1 Like   #2
Send an email with the pictures or the link to Eric. He does a ton of lens repair work and he would know if it is even possible and will provide an estimate.
Eric's Homepage
Eric Hendrickson
pentax27@aol.com
188 Shoffner Rd
Sharps Chapel, TN 37866
Fax/phone 865 278-1051
Tim
02-26-2014, 09:08 AM - 3 Likes   #3
Bent filter rings happen quite often and there is a tool specifically made to repair it.
Small Lens Vise Tool Repair Filter Ring Professional 30mm to 105mm Steel New | eBay
02-26-2014, 09:39 AM   #4
QuoteOriginally posted by elliott Quote
I officially learned something new today. Thanks for the link.
Tim
02-26-2014, 11:28 AM   #5
Just1MoreDave's Avatar
I use wood scraps to make a form that fits the outside of the filter ring, with the curve it's supposed to have, and a long piece with the inside curve on one end. Then I can push or tap the dent out. I usually have to reshape the inside piece a few times as it gets damaged. Wood won't cause any more damage to the filter threads. I keep going until a filter fits again.
Whatever you use, patience is best. The lens doesn't need any more shock damage.
02-26-2014, 11:30 AM   #6
fretlessdavis's Avatar
That's an awesome looking tool. $50 is worth it to have around in case of a drop, but would also pay for itself in buying 2 lenses with dented rings...
03-01-2014, 09:33 AM   #7
malenisjaj's Avatar
Fixed!
Well, I didn't have to order tool for $50. All I needed is little bit of searching and then I found this:
Now, lens is fixed and this are the pictures of my way of doing it with tools that are quite primitive (in design) compared with those on yt video.
https://drive.google.com/folderview?id=0ByeW6kWG57WwM1JTd1ZMTHBIc1k&usp=sharing
Kind regards.
Edit: Most important, with using wood, the metal threads stays intact!
03-31-2014, 01:49 AM   #8
malenisjaj's Avatar
Well, due to fall (on the floor?) in the customs office (or some place like that), I noticed that A 35-105 has the focus to infinity problem: 0.5mm before it reaches the end is the focus to infinity; after that it's little bit blurry. It doesn't bothers me that much but little devil inside of me is telling me that I need to have that feel: when it reaches the end that I know it's focus to infinity.
What do you think?
03-31-2014, 04:49 AM - 1 Like   #9
That is common for many lenses, especially zooms because temperature can affect it. Better to go to far than not far enough. I don't have the 35-105, but 0.5mm sounds acceptable to me.
k-mount, pentax lens, slr lens
Can LCD screen scratches be repaired? skid2964 Troubleshooting and Beginner Help 2 06-24-2013 10:17 PM
Can this be done? kaiserz Pentax K-01 19 01-04-2013 10:54 PM
Can a broken flash be repaired Tranzistors Flashes, Lighting, and Studio 3 09-15-2010 12:36 PM
Can my K200d be repaired? kevinfox203 Pentax DSLR Discussion 28 05-24-2010 07:51 PM
Can a lens be repaired? The Kurly One Troubleshooting and Beginner Help 16 02-16-2010 03:59 PM
All times are GMT -7. The time now is 06:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
