04-16-2008, 06:27 PM   #1
Tuner571's Avatar
Need help with macro decision!
Hey everyone, I was wondering if it would be better to buy macro adapters for my SMC-A 50mm f/1.7 prime or my DA 16-45mm zoom. I wonder because everyone on here says that primes are always sharper then zooms so I was wondering if it would better to buy the macro adapters for the 50.
Thanks, Cory
04-16-2008, 06:58 PM   #2
heatherslightbox's Avatar
Cory,
How about going in a different direction, entirely--instead of getting macro adapters for the 50, pick up a set of cheap extension tubes on Fleabay. Since you're putting another lens in front of your 50, there will be a decrease in IQ if you use macro adapters. The extension tubes are hollow and go between your body and lens, so there's no decrease in IQ. I have a 50mm set that I use and I like them a lot. With a 50mm set, you'll get a 1:1 ratio just like a dedicated macro.
HTH,
Heather
04-16-2008, 07:03 PM   #3
Tuner571's Avatar
QuoteOriginally posted by hwblanks Quote
Cory,
HTH,
Heather
Hey Heather, thanks for the info. I have never seen these extension tubes before, are they usually cheaper then macro adapters that screw onto the front of the lens?
Cory
04-16-2008, 07:05 PM   #4
Moderator Emeritus
If you don't want to or have the $$$ for a dedicated macro lens then I'd agree with Heather. You might also want to consider this thread to have a look at:
https://www.pentaxforums.com/forums/pentax-photography-knowledge-base/24622-m...l-bellows.html
04-16-2008, 07:17 PM   #5
Cory,
A manual set of extension tubes is definitely cheaper than a set of closeup lenses. For example, the cheapest new set of 49mm closeup lenses is $37.50. Here is a Fleabay listing for a set of extension lenses for you to see what I mean:
Macro Extension Tube Set for Pentax K,PK mount camera - eBay (item 360043689155 end time Apr-23-08 11:29:57 PDT)
This seller is the seller I got mine from.
If you want to see some examples of what extension tubes + a FA43 can do, check this out:
macro_and_close_ups Photo Gallery by Heather at pbase.com
HTH,
Heather
04-16-2008, 07:20 PM   #6
omega leader's Avatar
2nd the extension tubes
I was using Vivitar extension tubes quite happily with my 50mm/1.7 before I bought my V105mm series 1 macro.
I got some nice images with that combination. The extension tubes cost my 3 dollars including shipping on fleybay as they were mislabeled as "T" mount.
04-17-2008, 03:15 AM   #7
Tuner571's Avatar
WOW, thanks for the info everybody. I think I will look into these extension tubes for my 50.
Thanks again!
adapters, k-mount, macro, pentax lens, slr lens
I need Decision help? Rupert Pentax SLR Lens Discussion 6 10-09-2010 12:21 PM
K-7 Hard Decision tsmith Pentax News and Rumors 24 05-23-2009 01:07 AM
Macro lens decision bwield Pentax SLR Lens Discussion 5 08-01-2008 11:33 PM
Need help making a decision paden501 Pentax DSLR Discussion 22 01-29-2008 07:55 PM
My DECISION is almost made - THAN THE SWORD Welcomes and Introductions 11 01-03-2007 11:55 AM
All times are GMT -7. The time now is 03:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
