03-01-2014, 02:04 PM   #1
Front Lens - Smudges, Dirt, Scratches & Cracks
From time to time there are posts about having small fine scratches on the front lens element and what they might do to an image. This guy took an old lens and essentially ended up destroying it, but taking pictures along the way....
03-01-2014, 02:30 PM   #2
SpecialK's Avatar
It's interesting alright. Now, where did I put that UV filter....
03-01-2014, 04:02 PM   #3
Canada_Rockies's Avatar
Interesting article. Fun, too.
03-01-2014, 04:53 PM   #4
kiwi_jono's Avatar
I have seen this one before but its still interesting.
While its true that you do need quite a lot of dirt and scratches before they have a noticeable effect under normal conditions, the results can be worse under some conditions. For example (and I have not tested all of these - but tempted to!):
* Stopped down a bit (like f11+ for example) is likely to produce worse results - because dirt is not as far away from in focus zone.
* Close focus on a subject - again because dirt is not as far away from in focus zone.
* Wide open + close focus, the effect of dirt / debris may be apparent in bokeh behind the subject. I have actually seen this happen even with relatively small amounts of dirt - especially with bokeh light discs.
As I say I'm tempted to set up a test with an old lens at some point because I'm still curious.
03-01-2014, 08:53 PM   #5
The f/8 and be there (journalists) have been known to clean the front of a lens with spit and their tie. In the day when journalists wore decent clothes, of course, and Tri-X was the norm.
front, k-mount, lens, pentax lens, scratches, slr lens, time
Lens Rental - Front Element Scratches interested_observer Pentax SLR Lens Discussion 3 03-09-2014 10:05 AM
Dust/dirt in Lens dngr Troubleshooting and Beginner Help 4 01-03-2014 03:29 PM
testing a lens for impact of scratches on coating toukan Pentax SLR Lens Discussion 5 12-19-2013 10:21 PM
Front to Back Sharpness: Distance setting on front of lens yoon395 Troubleshooting and Beginner Help 18 09-08-2010 04:33 PM
EEK Bayed!! "No Scratches" = Alot of Scratches?? rdrum76 Photographic Technique 28 11-29-2007 03:13 AM
All times are GMT -7. The time now is 03:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
