Originally posted by schnitzer79 rome is great! you will enjoy taking photos.last year when i went i just took my 18-135 which was mounted 95% of the time and only used my 50mm f1.4 for night time when i wanted to walk around light and would be much better in low light.
Thats useful to know
Originally posted by timo My M28/3.5 was probably the most used,
I appreciate the arguments for a wide-range zoom. Personally I find that a zoom tempts me to whack off vast numbers of shots without much consideration, and anyway I hate walking around with a heavy lens on the front of the camera.
I like the 28-30 fov on aps-c so I will probably end up with the F28
Hopefully I'm quite restrained with the 18-135 - I find I continually remind myself that shooting loads entails processing loads!
---------- Post added 3rd Mar 2014 at 13:02 ----------
Originally posted by Michaelina2 Seems doubtful you will be after portfolio quality stuff this go around, so pairing your K-5 to your 10-17, F28 and 18-135... you should be good to go.
BEFORE you head-out, I suggest you take some time (say) a couple of weekends and practice photographing local settings (Hampshire, UK... eh?) similar to what you may encounter in Rome. If you plan to shoot church interiors, ask permission to practice in your local parish church (offer to give your photos free to your host, if anything turns out OK... how could they say 'No'?)... Winchester Cathedral, perhaps. Ruins...? Consider local Roman and pre-Roman stuff... Large open-air structures like the Coliseum...? Consider doing some panoramas of Fratton Park. You get the idea. Being able to 'work the setting' with confidence using what you know will be much more rewarding than trying to do justice with a new piece of kit.
Rome is HUGE and so diverse that it's easy to become lost/overwhelmed... In order to narrow things a bit, it might make sense to focus on one theme and plan to return, again. I've visited to Rome several times. For my first, the focus was ancient Rome; the second, Religion; the third, Renaissance; the fourth, Gardens; the fifth, just people/fashion/street life and food. You are fortunate to live so close... well, follow-up visits should be quite easy to plan once you know what to expect.
Anyway... my two cents...
Ciao...
10-17, F28 and 18-135:
I like this combo; I took very similar to Jordan.
Off to London soon so will be trying out a few ideas there - fratton park is a good idea though.
focus on one theme:
a great idea, too obvious for me to think of!
Only problem is that it commits me to going back again - not that my wife will mind
---------- Post added 3rd Mar 2014 at 13:15 ----------
Originally posted by RobA_Oz I travelled there three years ago with a swag of lenses, and found that most of the time I needed very wide (the DA14/2.8 - that extra stop over the DA15/4 is handy in dim interiors, but it is heavier and the hood is a monster) or moderate wide to normal (the FA31/1.8). Since that time, I've bought the DA18-135 and find that, stopped down a little, it's more than adequate for most travelling needs, and it's light for what it is. I've also added the DA15/4 for exactly the same reason. Very rarely, I've wished that I had something longer than the 135, but not enough to be worried, and I wouldn't want to carry the extra weight. I do take the FA31/1.8, FA43/1.9 and FA77/1.8 for use when I'm staying in one spot for a while, and want to photograph detail with the best possible lenses, but carrying everything while sight-seeing is more than my back likes, these days.
I found the 15 and the 18-135 really useful in Jordan a few years ago. I felt that the 18-135 struggled in Iceland last year - the weather was continuously damp and cloudy. I know Rome should be better in this regard but I'll be in and out of a lot of buildings I imagine.
Choices...
