03-08-2014, 06:20 AM   #1
50mm comparisions -- my head is spinning
I am new to Pentax and just bought a K5, which I LOVE! I have been reading and researching the 50mm for about a week and I still feel confused. My budget is no higher than $125/$150. From my understanding there are 4 different kinds
50mm M 1.7 -- all manual
50mm A 1.7 -- auto
50mm FA 1.7
50mm F 1.7
What is the FA & F?
I know I have a crop frame and these are closer to a 75mm.
03-08-2014, 06:29 AM   #2
boriscleto's Avatar
F was the first AF lens series made by Pentax, from 1986 to 1991.
FA was the second series of AF lenses made by Pentax, from 1991 to the present (FA 50/1.4).
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
The A 50/1.7 is well within your budget. The F might be available for less than $150, the FA is somewhat rare and usually more expensive (though I got mine for $100 on craigslist).
Pentax Lenses - Pentax Lens Reviews & Lens Database
Pentax M 50mm f/1.7 samples - PentaxForums.com
SMC Pentax A 50mm F1.7 Samples - PentaxForums.com
Pentax F 50mm f/1.7 samples - PentaxForums.com
SMC-FA 50mm 1.7 - PentaxForums.com
03-08-2014, 06:32 AM   #3
50 mm is 50 mm is 50 mm regardless of sensor. They will all be like 75 mm lenses on a crop sensor.
M requires green button to meter. I would avoid this one.
A does not and also allows PTTL flash metering. A good inexpensive choice if you are willing to forgo autofocus.
F adds auto focus. I carry a 50mm F 1.7 almost all the time. I'm not upgrading until I get a serious bargain.
FA adds slightly better flash automation.
03-08-2014, 07:23 AM   #4
These are great resources! I was looking through the F & FA examples (I also looked on Flickr) and some of the bokeh on the F looks smeared like. Is that from user error?
QuoteOriginally posted by boriscleto Quote
03-08-2014, 08:52 AM   #5
mgvh's Avatar
For $125/150, you should be able to get the new DA 50 f1.8 used. I have the M50 f1.7 and A50 f1.7 also. Those latter two have their charms, but if I just had to choose one to keep, it would be the DA 50.
03-08-2014, 09:03 AM - 1 Like   #6
QuoteOriginally posted by julbelle Quote
I am new to Pentax and...have been reading and researching the 50mm for about a week and I still feel confused...
Confusion is easy to overcome, if you are willing to take some time and do a little work...
Did your K-5 purchase include the 18-55 kit lens? If No, get one (used is OK). If Yes, do some research on it and identify it's strengths. You may read a lot about its weaknesses, but put those comments aside. Instead, everyday, shoot to its strengths for (say) six months. Learn everything you can about it and your K-5, then return with your question (if it still remains ). Should you return, you may have a better question and be better prepared to understand suggestions offered by others.
Want to learn more? Check this out:
http://dtmateojr.wordpress.com/2012/04/20/zoom-lens-vs-prime-lens/
...my 2 cents... M
03-08-2014, 10:00 AM   #7
TaoMaas's Avatar
You are WAY over-thinking this. There's not a tremendous amount of difference in the lenses you listed. I have a few copies of the M50 f1.7, but those are left over from my film days. If I were buying now, I'd look for an A, F, or FA version, simply because of the convenience. However...I do think you're smart to be considering these lenses because they're all full-frame. When (or if....heaven forbid) Pentax comes out with their full-frame camera, you'll be ahead of the game. For what it's worth...I once read an article that said that almost all 50mm lenses are decent because it's such an easy lens formula. (Granted, this was during the film days. With digital, this may not be completely true.) If you're going to anguish over a lens purchase, save it for wide-angles, telephotos, or zooms.
03-08-2014, 10:58 AM   #8
Forget about crop factor; FOV and DOF will be the same as the 18-55 or 18-135 lens @ 50mm and equivalent apertures on your K5.
Crop factor is only of interest if you're comparing FOV on different systems (APSc, m4/3, FF, and so on).
03-08-2014, 11:16 AM   #9
Just1MoreDave's Avatar
QuoteOriginally posted by mgvh Quote
I agree with that. All of the Pentax 50mm f1.7 lenses (M, A, F, FA) use the same optical formula. The only optical differences are in the lens coatings, so there are small color rendering differences in each series. It's tough to see these unless you have all of them for a comparison. Physically, the M has the best build, the A is cheap but a well-treated copy disguises its cheapness. The F was built with no regard to manual focus and the FA is only a little better. If you buy and sell a lot of stuff, you eventually will see most or all of these. It would be a lot of work to take photos that show differences between these versions.
The DA 50/1.8 is somewhat different. It has seven aperture blades, new coatings, a plastic mount and a 52mm filter. And you can get it brand new or barely used, while the other ones haven't been made for a while. The aperture blades can make a distinct difference in night shots that anyone can see. The lens has a correction profile but a 50mm usually doesn't need one.
03-08-2014, 12:08 PM   #10
Eyewanders's Avatar
Personally, if you're quite interested in really *learning*, I would pick up the most simple version possible, namely the M 50mm 1.7 - this will allow you to gain the most amount of understanding in the shortest amount of time. Focus and aperture setting will be done manually and if you're shooting in manual mode you'll set the shutter speed on-camera and can use the Green button to quickly allow the camera to meter for you and work up or down from there.
Also, the M will by far be the cheapest and easiest place to begin.
03-08-2014, 12:30 PM   #11
What lenses do you have now?
03-08-2014, 01:04 PM   #12
QuoteOriginally posted by tibbitts Quote
Originally I had a Canon T3, kit lens, flash, 50mm 1.8, and a 70-200mm lens. The T3 was nice but I didn't love it, came across a used K5 with the 18-55 kit lens and LOVE it. Sold all my Canon gear and need to build my Pentax gear up. This link has helped a lot Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
I want something that I can use for portraits and gives me nice bokeh, I do like the kit lens I just want more options I am trying to buy a M 50mm 1.7 off Craigslist to learn, but I also want one that has auto focus and and auto aperature. It just feels like there are so many options for a 50mm it's over whelming.
03-08-2014, 02:48 PM   #13
QuoteOriginally posted by Michaelina2 Quote
Zoom Lens vs Prime Lens | Demo Mateo
...my 2 cents... M
I am learning a ton from this guy! Thanks! I'm on this blog now Understanding Your Lens (Part 1) | Demo Mateo
03-08-2014, 04:57 PM   #14
I think there is a F 50mm f/1.7 on the marketplace right now.
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/253501-sal...-50-1-7-a.html
The 50mm optical design has been well established and it's kind of hard to find a bad 50mm lens. Even the older manual ones can capture great images.
I agree with others who say get a FF lens if you can. The build quality is good and you will be ahead of the game if/when a FF body is released. Get an A, F, or FA lens for the automatic aperture control. I got my FA 50mm f/1.7 from eBay in camera/lens/accessory bundle. My initial thought was to sell of the extra goodies but I fell in love with the accessories and use them well. It made the perceived price of the lens lower than if I bought it separately.
03-08-2014, 05:16 PM   #15
PEG Moderator
Kerrowdown's Avatar
This maybe of interest to you too.
https://www.pentaxforums.com/forums/26-mini-challenges-games-photo-stories/25...-giveaway.html
50mm, fa, k-mount, pentax lens, slr lens
Pentax 645, 67, Mamiya RB and 645... My head is spinning. fretlessdavis Pentax Medium Format 40 11-22-2013 09:52 AM
Tripod Head - Can I add Rotation to my current ball head claimed4all Pentax Camera and Field Accessories 5 10-11-2011 09:34 AM
People Excedrin Headache #57: There is a knife on my head jmbradd Post Your Photos! 6 09-10-2010 07:43 PM
My head is spinning. 16-45mm or 17-70mm or... Unsinkable II Pentax SLR Lens Discussion 10 05-16-2010 11:30 AM
tripod head spinning off :( rdrum76 Pentax Camera and Field Accessories 9 01-27-2009 09:46 AM
All times are GMT -7. The time now is 08:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
