03-10-2014, 01:32 PM   #1
K28 3.5 aperture ring
I just picked up a copy of this lens for $50 because the aperture blades are slow, but that should be fine. My question is that at 3.5 (wide open) the aperture ring doesn't really click into place, it just kind of stops. Is this normal?
Thanks
03-10-2014, 01:46 PM   #2
ironlionzion's Avatar
Mine doesn't click in place either, at least not as firmly as the other stops. The ring still wants to sit at either 3.5 or 5.6, no in between. Probably normal.
03-10-2014, 02:01 PM   #3
Mine clicks between 3.5 and 5.6 (4?), but not at the 3.5.
03-10-2014, 05:20 PM   #4
baro-nite's Avatar
Click, click, click.
03-10-2014, 06:01 PM   #5
monochrome's Avatar
QuoteOriginally posted by baro-nite Quote
Me too.
03-10-2014, 06:35 PM - 1 Like   #6
Just1MoreDave's Avatar
If you have a JIS screwdriver, you can take off the mount, clean it up and regrease the aperture ring. The clicks are simple. The aperture ring has teeth inside, like the upper right here:
There's a bearing trapped between the ring and lens body, probably just below the orange diamond like here:
The bearing has a spring pushing it out against the teeth. Usually that's a flat piece of spring steel, riveted on one end to the inner lens body. The bearing can pop out unexpectedly when you slide the aperture ring off, so be ready, maybe do that in a plastic bag to capture the bearing. The original grease might have dirt packed into it. An old toothbrush and some mineral spirits can get all that grease off. The ring will work OK with no grease but just a dab will make it move smoother.
03-11-2014, 05:36 AM   #7
what kind of grease would work best?
03-11-2014, 05:46 AM   #8
Not a Number's Avatar
I've been using a product HELIMAX-XP™ Camera Lens Telescope Optical Instrument Focusing Helicoid Grease w/ PTFE to relube my lenses. It is a high quality lubricant and I'm very satisfied with the results. A couple of other member have used it too and are pleased with the results.
You can find it on ebay and Amazon or direct from the manufacturer. They sell and ship internationally. Reasonably priced and a little goes a long way. A must if you will be buying more legacy lenses.
MicroLubrol? HELIMAX-XP? Camera Lens Telescope Optical Instrument Focusing Helicoid Grease w/ PTFE 1oz 28g
03-12-2014, 07:39 AM   #9
It now clicks. I guess just working it loosened up whatever grit was in there. I will still probably clean it though. Thanks for the tips.
03-18-2014, 11:12 AM   #10
Quick question, the screws on the back of this lens are really tight. What is the best way to loosen them? Normally I would spray some WD-40, but that is probably not a good idea for a lens.
03-18-2014, 12:20 PM   #11
monochrome's Avatar
QuoteOriginally posted by millsware Quote
Again (RE: DaveInPa) - I think they're probably JIS cross-type and not US/EU Phillips. That can make a difference applying torque (and can strip them if you use Phillips).
I don't see where you are. Have you considered sending it to Eric for a CLA? He adjusted the colimation on a K28/3.5 for me a few years ago
aperture, k-mount, k28 3.5 aperture, pentax lens, slr lens
For Sale - Sold: Close-Up filters, Pentax K28/3.5,M 50/1.7, Kenlock Lens and ME (repair) Albino_BlacMan Sold Items 7 04-13-2013 11:34 AM
For Sale - Sold: K28 f/3.5 robbiec Sold Items 2 10-31-2011 01:56 AM
k28/3.5 , very impressive nirvanaguy19 Pentax SLR Lens Discussion 2 02-20-2008 11:22 PM
K28/3.5 schmikey Pentax SLR Lens Discussion 4 07-11-2007 05:34 PM
All times are GMT -7. The time now is 02:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
