Originally posted by konraDarnok I was thinking about the radioactive glass the other day. If you set your white balance manually, wouldn't that compensate for any cast the (decaying) thorium doped glass might induce? (even if it is a pleasant effect with the cast, I'm just curious if manual white balance gets rid of it.)
Also does the lens give you any powers? X-ray vision or super strength as a consequence of the radiation?
Far as I understand, the WB will take care of the yellow cast. Under artificial lighting, the lens should give a more neutral WB without touching the cam
The radiation isn't strong enough to do anything to you, unless you have it within 4" of your body for 50 years, or something like that. We're getting hit with more radiation right now (and through cell phones) than the lens can produce. Nothing to worry about, unless you've had the lens with you for ~20,000 days...showered with it...slept with it under your pillow...etc. There were some that were stronger, but I don't believe any of us would be using them.
