03-14-2014, 08:13 AM   #1
malenisjaj's Avatar
smc 300/4 (77mm) and CPL 67mm on APS-C?
I was wondering is 67mm CPL filter gonna make vignetting effect on SMC 300/4, which has 77mm diameter, if we count that I'm using k-5 ii (aps-c)? I'm thinking about step-down ring.
Thanks!
03-14-2014, 09:34 AM   #2
carrrlangas's Avatar
I had that lens but never tried filters as I already needed to stopdown f/11 to get good results on K-5. I donīt think it will vignette with the step down ring. You are just covering 5mm of the radius so it should be ok.
03-14-2014, 09:59 AM   #3
MadMathMind's Avatar
It's worth a shot. You can get a ring for $5.
I would not expect it to vignette I have used a 72mm filter on a 70-200mm 77mm front element. No issue there. Haven't tried it on my DA300. I can try it later and see if there's an issue with 72mm filters. At least gives you a starting guess.
03-14-2014, 10:11 AM   #4
glasbak's Avatar
Your lens will not give more vignetting, but will become a SMC 300/4.5.
03-14-2014, 10:16 AM   #5
QuoteOriginally posted by glasbak Quote
depending on the polarization angle, the CPL filter can take up to 1.5 stops of light. I think it will take half a stop at any angle. So Iīd say something like f/5.6. Given the weight a tripod collar and tripod or monod are almost a must... Thatīs why I sold mine.
03-14-2014, 10:33 AM   #6
Just1MoreDave's Avatar
Just a little. I set up my K-7 and K300/4 on a tripod, focused to infinity, f4, and took three shots of a solid blue sky. The first shot was with nothing on the lens, hood retracted. The second was with a 77-72 and a 72-67 stepdown ring, no filter, no hood. The third was with those stepdown rings stuck into the end of the hood and the hood extended fully. In Lightroom, I looked at one corner of the shots for the R, G and B percentages.
1: R 65.9, G 69.3, B 95.9
2: R 62.6, G 65.6, B 94.1
3: R 60.0, G 62.9, B 92.7
You don't really see darkened corners. I thought I'd see something like that. The DA* 300/4 has the same filter size.
03-14-2014, 10:44 AM   #7
glasbak's Avatar
QuoteOriginally posted by carrrlangas Quote
The aperture is 300/67 = rounded 4.5, no transmission blocking filter will change that.
03-14-2014, 11:50 AM   #8
malenisjaj's Avatar
Indeed, this is a great forum. Thank you all!
77mm, cpl, k-mount, pentax lens, slr lens, smc
67mm CPL on 52mm and 58mm lenses? malenisjaj Pentax SLR Lens Discussion 2 02-17-2014 12:34 PM
For Sale - Sold: Marumi 77mm UV and Tiffen 77mm CPL zhuxyg Sold Items 2 05-05-2013 07:39 AM
Lens compression effects on APS-C and full frame tyronfall Pentax SLR Lens Discussion 56 05-14-2012 08:17 AM
SMC 67 Macro 4/135 on APS-C samples jt_cph_dk Pentax SLR Lens Discussion 8 04-04-2012 03:25 AM
Full frame 300 f2.8 plus 1.5x converter vs APS-C 300 f4 Buckeye Photographic Technique 2 04-22-2011 03:02 PM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
