03-21-2014, 08:26 PM   #1
MadMathMind's Avatar
Hood + Filter
I have just acquired a screw-in metal hood (49mm diameter) for my Pentax legacy glass. The hood has 58mm filter threads on the outside edge so that filters can be attached to the outside of the hood. This gives me options:
1) Purchase a 58mm --> 72mm step up ring and attach my big filters to the outside of the hood
2) Purchase a 49mm --> 72mm step up ring and acquire a 72mm screw in hood to attach to the filters
3) Purchase a 49mm --> 72mm step up ring, 72mm --> 49mm step down ring and sandwich the filter between the hood and lens: lens | ring | filter | ring | hood
Option #3 comes with the risk of vignetting, but the lenses I will be doing with this are 50mm and above, so it might be ok still. (I can check this, I suppose). #3 is not my preferred option, so I'm weighing between 1 and 2. My question is: does #1 negate the benefits of a hood? If I attach the filter to the hood, will being so far away from the lens make it less effective?
The filters I would use are a variable ND and a polarizer.
03-21-2014, 10:40 PM - 1 Like   #2
johnyates's Avatar
You don't want to be attaching filters to the end of your hood. Light striking the filter will cause flare. Put the filter on the lens, and then screw the hood into the filter.
03-21-2014, 11:27 PM   #3
AquaDome's Avatar
Those threads on the wide end of the hood would hold a lens cap nice and snug.
03-22-2014, 02:45 PM   #4
Thanks! I think I will do option #2. Then I can still rotate the filters with the hood attached, too, which is nice!
49mm, 58mm, 72mm, filter, filters, hood, k-mount, lens, option, pentax lens, purchase, slr lens, step
Comparison; Hood, CPL, ND Filter rbefly Photographic Technique 6 12-12-2012 05:24 PM
For Sale - Sold: Samyang 85/1.4 + filter + extra hood ihasa Sold Items 3 12-03-2012 09:37 AM
Attaching 43mm filter to 21mm lens hood CPS Visitors' Center 7 09-20-2012 02:02 AM
Lens hood or polarizing filter? el baroda Pentax DSLR Discussion 11 07-22-2012 06:13 AM
All times are GMT -7. The time now is 12:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
