Show Printable Version 4 Likes Search this Thread
03-24-2014, 08:51 PM - 1 Like   #16
pacerr's Avatar
The DA* 300's a fantastic lens, BUT . . . remember, you can't 'zoom with your feet' in the nautical environment. If boating use is the primary consideration I'd choose the zoom with no hesitation.
A zoom makes a 'whale' of a difference there, as does a body that has the robust MPS to allow cropping a bit for eye catching composition.'
I'd suggest the DA 60-250 . . . or a very economical trial of the DA 55-300 to see if that FL would work. If you've got good composition even that lens won't cost you commercial opportunities if your technique is good and your shots are worth publishing in the marine world.
Good luck.
H2
03-25-2014, 10:09 AM - 1 Like   #17
ironlionzion's Avatar
I was also lured into the classic glass and look of the F*300. I just picked up a nice copy off ebay for $1030 shipped. They do command a premium over used DA*300 because of their rarity and collectors status, but I like to think the screw drive will outlast SDM and be much simpler and cheaper to fix if something goes wrong. The F*300 and DA*300 have nearly identical IQ, but the F* weighs less but lacks WR.
03-25-2014, 05:13 PM   #18
Ironlionzion, I am under the spell of the classic glass as well. I think the advice of the posts is sound and I will follow the wisdom behind acquiring a 60-250 DA* for the majority of my needs. However, I think I just need to bite the bullet and also start saving a little for the F*. Won't sleep till I get it!
Thanks!
03-25-2014, 10:02 PM   #19
steve1307's Avatar
I agree the DA*60-250 would be the ideal for versatility, but I can disagree with the 300mm either.
A couple of weeks ago i went shooting 18 foot skiff racing in Sydney Harbour. Even though winds were moderate our launch couldn't keep up with the the racing skiffs.
I had a DA*300, a DA55-300 and DA18-135 used while out on the water. (i dont have a DA*60-250) 2 bodies K-7 and K-5IIs
Of about 650 shots 340 were with DA*300 (which I was preferring, fixed on my K-5IIs) but I definitely need to be able to zoom to much shorter to capture the action as it came closer. I did use the 300 for some "close-up" detail in tandem with a wider angle when the action did get closer
About 180 shots taken with either DA zooms were within the 60-250 range.
130 were wider but quite a few of these were, general Sydney harbour scenery, overall race scene and the finish celebrations when we could get a lot closer.
If I had a 60-250 it would have gotten a least equal use to the 300.
Best advice is .....Get both
03-26-2014, 04:40 PM   #20
Too true! I like the idea of both and no doubt, I will enjoy shooting with the F* at times. I can only imagine it is like driving a classic sports car - not all the bells and whistles but plenty of charisma. It's so nice to have a forum of like minded people, kind of like a polarizing filter for common sense - it reduces the unwanted effects of overspending one's hobby budget. At least all this camera gear is nothing compared to the hole in the water a boat can be...
da*, da* f* star 300mm, k-mount, pentax, pentax lens, slr lens
SMC Pentax-DA 55-300mm F4-5.8 ED vs SMC Pentax-DA* 300mm F4 ED [IF] SDM Budster48 Pentax SLR Lens Discussion 12 06-30-2013 11:00 AM
Pentax DA* 60-250mm @ 250mm vs DA 55-300mm @ 300mm resolution bwDraco Pentax SLR Lens Discussion 9 07-07-2012 05:16 PM
Pentax DA* 60-250mm f/4 vs Sigma 100-300mm f/4 APO slackercruster Pentax SLR Lens Discussion 7 04-13-2012 06:35 AM
IQ: Pentax DA 55-300mm vs Pentax-F 70-210mm 7.62lew Pentax SLR Lens Discussion 6 06-18-2010 02:09 AM
DA* 200mm f 2.8 vs DA* 300mm f 4 jmbradd Pentax SLR Lens Discussion 27 03-08-2009 08:38 AM
All times are GMT -7. The time now is 03:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
