Hi All - Yet another 'Lenses for travel' question I'm afraid, but hopefully slightly different.
I'm traveling soon and looking for suggestions about lens options when mixing film & digital bodies. Last time I took my K-5 (without grip) and DA17-70/4 which was sufficient for almost everything (I would have liked my M135/3.5 for a bit more reach when it mattered). As I might be mixing film & digital bodies, the above won't be sufficient and I need another plan. Most of my shots will be either wide-angle or at long end of the longer lens (if it's a zoom).
I'm limited to quite a small bag (by preference as much as anything else) and have space for two bodies and 3 lenses. My FA20-35/4 is a given as this covers the wide ends of film & digital sufficiently and i'd like to add to this a fast prime and a longer lens (or 2x TC). My A35-105/3.5 would be ideal but it's too bulky & heavy (I'd probably have to leave the fast prime behind). I'm preferably looking to use only 49mm & 58mm filter sizes. I'm not looking to add to my lenses, an FA77 or K/M85mm might be ideal but aren't options right now.
Fast prime choices are: FA35/2, FA43/1.9 & FA50/1.4
Longer lens choices are: M135/3.5, F35-70/3.5-4.5, Tamron ADII 35-80/3.5, SMC-TAK105/2.8 (not ideal) & FA50/1.4 + 2xTC.
Whilst the FA43 should be a given, I feel the 50/1.4 might be more versatile (and an option with the TC) considering I will have the FA20-35. The FA35/2 is basically covered by the 20-35 and is unlikely.
My current plan is to go with: FA20-35, FA50 & M135/3.5 - although since typing this I'm thinking I might be able to swap the M135 for FA43 & 2x TC - making FA20-35, FA43, FA50 & 2x TC.
Any thoughts/suggestions?
John.
Reason: Spelling correction
